38mm wastegate?
Old May 25, 2015 | 07:06 PM
90zcrex's Avatar
Default 38mm wastegate?
My setup will be:
stock 6.2l
pt7675 or tc7875 rear mount
2.5" hotside piping
Is there anyway a tial 38mm wastegate would work in this setup to hold 10-12psi? I've got a tial 38mm already and wondering if it's just a waste of time to try it or could it possible work with good wasegate placement?
Old May 25, 2015 | 08:02 PM
66Chevellelq4's Avatar
I donk think i know of anyone running one that small. I do know that good gate placement works wonders though. If it doesnt work switching gates isnt too hard
SCott5's Avatar
I run twin 38s. I say go twin 38s or a single 44-46
Old May 25, 2015 | 08:13 PM
chiaj144's Avatar
I run a 38mm on a 5.3 with a 7675. Will control down to 5lbs. Haven't tried any lower. Placement is key.
Old May 26, 2015 | 05:48 AM
yenkomike's Avatar
I run a 38 mm on my 6.0 / s480 -83 /1.25 t4. it holds 10# steady I have not tried any lower.but primary wastegate placement is the key.
Old May 26, 2015 | 06:03 AM
90zcrex's Avatar
Sweet it looks like I will try it out, I should be able to get the wastegate in a really good position so I think it just might work thanks guys.
Old May 26, 2015 | 05:28 PM
SPRAYED 01's Avatar
I run a single 38mm gate with my 88mm comp turbo and 370ci. Been on the car for like 5 years with 3 different turbos and have always had good results. I run as low as 6psi with out issue.
