What turbos for 441 LSX?
Old Jun 10, 2015 | 12:12 PM
Mastaforga's Avatar
Originally Posted by chuntington101
Could you not go for an air to air intercooler? Any air to water setup will heat soak over time. With a decent sized air to air unit you can mitigate some of this and also get much quicker recovery times. It does require the intercooler to be mounted in a location with good airflow. Also you need to think about where you radiator and oil cooler are located and try to reduce any impacts you might have on them.
Got any pics of your truck? Is you radiator / oil cooler mounted at the rear?
I could put up a picture of my truck, but it will be several hundred pictures. I'm fabricating the new cross members for engine and transmission relocation, and still making the cage style bed to replace rear half of frame. It's torn down to as many pieces as possible.
Heat exchanger for water/air intercooler, radiator, and trans/oil coolers will all be rear mounted. I'm having a local shop build me a short 2 inlet to single outlet air/air intercooler between turbos and intake, for any heat soaking problems and for a backup incase a roll or bounce breaks the heat exchanger or pump.
Old Jun 10, 2015 | 02:21 PM
chuntington101's Avatar
Why use an air to air as a backup and not the primary? Your not going to break an air to air and it will be more efficient. Just look at all the endurance style race series out there using turbo engines, very few cars are using air to water intercoolers. F1, Le Mans, WRC, WTCC, they all use air to air intercoolers. And there is a reason.
The only one I can think of would be the MacLaren GT3 cars. I'm not even sure if they do use air to water intercoolers (the road cars do). Everything else out on track wil use air to air!
Old Jun 11, 2015 | 01:26 PM
Mastaforga's Avatar
I guess it really isnt a backup, they will pretty much be working in unison, the turbos will feed into the air/air, then into the intake wich will have the water/air. I just want to get the intake temp as low as possible and ill be using a large heat exchanger to keep heat soak down.
Old Jun 11, 2015 | 01:33 PM
Mastaforga's Avatar
Originally Posted by 66Chevellelq4
Pics of truck?! Please hahah
Its a 2003 silverado 1500 single cab with the rear half of the frame cut off and a big hole in the cab where the firewall use to be and no fenders right now...
Nothing special yet. When I gain some good progress, ill start a thread of the build on an offroad forum. Ill put the link here when i do
Old Jun 11, 2015 | 02:07 PM
66Chevellelq4's Avatar
If your heat exchanger fails or gets heat soaked wouldnt it be heating up the air your air to air intercooler just cooled down? Seems like an accident waiting to happen. For desert racing and extended periods of time at WOT, it seems as though the water to air would have a tough time keeping up. Only a suggestion though, its your truck!
Old Jun 11, 2015 | 06:48 PM
Mastaforga's Avatar
Good point... Lol can you tell I'm new to turbocharging?
This is why I'm a firm believer in asking other people who know what they are talking about.
Old Jun 12, 2015 | 01:05 AM
Big air to air for the win!
Just make sure it's over speced. Don't be putting in a little 6 inch high core. Make it as big as possible. If you radiator is going to be rear mounted then you won't have to worry about the intercooler blocking airflow to it.
Old Jun 12, 2015 | 03:22 AM
stevieturbo's Avatar
Any system will fail to "keep up" if it is of inadequate capacity.
Fix is simple, build it with more capacity than it will ever need, then it will always have good cooling ability within it's operating environment
A bad setup is a bad setup whether its air or water used as a cooling medium.
Each can have it's ow benefits though.
On the positive side for a water based system, and if you are saying there is lots of slow speed stuff...ie low airflow. Then you could use an aircon system to try and assist water cooling for the charge cooler unit.
Other than that then you'll need fans with enough airflow to try and keep things as cool as possible, but that applies whether it's water or air.
Old Jun 15, 2015 | 03:24 PM
Orr89rocz's Avatar
366 is a great turbo. But bigger size so check your spacing
Else i'd look at a turbonetics hurricane, 6668 or something around that. Very compact. Good price. Spool very fast and be plenty for up to 1000.
I got the 7268 on my 400 and they work great.
Plus its hard to beat turbonetics warranty and service! I had an accident and they took care of me no questions asked
Old Jun 19, 2015 | 04:04 PM
Mastaforga's Avatar
The front clip will be cut off and a fabricated bar chassis will take its place. The engine will be moved boackwards about 2 feet, and customs shock towers.
I got all the space in the world lol. Might as well stick 2 turbo engines in there for the wow factor
Old May 27, 2016 | 06:22 PM
Black_Phantom's Avatar
Originally Posted by Mastaforga
Built a couple N/A ls7 and lsx 454's for some buddies cars and trucks.
This will be my first FI build, going in my personal stock frame prerunner...
Current Parts-
lsx tall deck block (will be 0 decked to about 9.3)
Callies Magnum XL crank 4.125" stroke
Callies Ultra I-beam rods
ARP head and Main Studs
Billet main caps
Diamond Pistons 4.125 bore 25.3cc dish 1.115 comp height
Still havent decided on heads or cam yet.
I also have 2 water/air intercoolers and dual 75mm throttle bodies to make custom cross ram intake.
I'm looking for around 900-950hp reliably with a flat torque curve to 7000rpm. What dual turbos would you recommend for fast spool at lower rpm and still have enough flow at the top end?
How much boost?
I also know nothing about different EFI controllers, I always just go stock or carbureted. Any Recommendations?
Look at my build and feel free if you have any questions.
https://www.facebook.com/almarzougi.a/posts/10204395498646075
Facebook Post
