View Poll Results: 370, 408 or other
370
19
61.29%
408
11
35.48%
other
1
3.23%
Voters: 31. You may not vote on this poll
Going twins on iron block, suggestions please
Old Jun 11, 2015 | 12:33 PM
DEFYANT's Avatar
I also voted for a 370. It will have less Piston wear, and the pin location, as well as the piston it's self will make for a stronger engine.
You use a 4.030" Piston, a 6.125" Rod, and the stock 3.622" stroke.
As for the turbos, do you have "ultimate" goals? As far as horsepower is concerned at least?
Old Nov 15, 2015 | 03:57 PM
stang_kllr's Avatar
Bump. Things were on hold while I was doing my nitrous car. Back on schedule. finally sending the block to get machined. Im going to be using wiseco pistons with lunati rods, unported 317s and a custom grind.
I don't have ultimate goals on what I wish to make, although I would be happy with 800+ reliable whp.
Does anyone have results from running a similar setup?
Old Nov 15, 2015 | 03:59 PM
stang_kllr's Avatar
Originally Posted by z2h8t
I'm doing a similar build. Same kit, 6665's, tick turbo cam, 317's and a factory cube lq4 with a stick. Should have the car together this weekend and dynod pretty soon. I'll let you know what it makes
Curious for any updates on this
Originally Posted by jmm98LS1
I run a faceplated t56. My hot/cold side is all custom, but it's laid out pretty similar to the new huron t4 twin kit. I haven't had it to the track or dyno yet, but in the car's previous nitrous life it would go mid-low 10s at 135mph weighing 3900lbs which is about ~675-700rwhp. I haven't weighed it with the turbos but it should be similar weight. I can tell you with the turbos on 10psi it's killing 28x10.50 MT's on the street like it never has before, so it's making at least the power it did on the nitrous. I've turned it up to ~14psi a couple times and I can lay into it in 3rd at 70mph and stripe the highway as long as I stay in it.
Did you ever take it and get track/dyno results?
Old Nov 16, 2015 | 07:27 AM
jmm98LS1's Avatar
Yep it made 663/661 on ~11psi and 890/813 spinning on the dyno on ~18psi. Our local 1/4 mile track went under this year so I road tripped to the closest 1/8 mile and just made a few shakedown passes. On 18psi it ran high 6.50s at 115mph with a mild 3psi launch and 1.57-.58 sixty foots. Race weight is 3750.
Old Nov 18, 2015 | 06:25 AM
stang_kllr's Avatar
Holy **** ***** dude. very nice! that's exactly where I want my car to be. Can you post pictures of your setup? or you do you a link to pictures, like a write up or something?
Old Nov 18, 2015 | 07:12 AM
jmm98LS1's Avatar
I never did get around to making a build thread for it. Here's how it looks all done. Lmk if there's anything in particular you'd like to see.
Old Nov 18, 2015 | 10:40 AM
hrlyhnx's Avatar
JMM
so you lost your wipers and A/C.....the bay looks clean and killer btw.
What made you decide to go ProFlow?
Old Nov 18, 2015 | 11:47 AM
jmm98LS1's Avatar
Originally Posted by hrlyhnx
JMM
Yes wipers and AC are gone. Knew I didn't want a plastic intake, and didn't think I could make the hi-ram fit.....so ended up with the pro-flo. I did a bunch of research and found several turbo combos doing very well with the pro-flo before deciding on it though.
Old Nov 18, 2015 | 01:12 PM
stang_kllr's Avatar
Man that looks very good! Love how you relocated the coils too. I would love pics of the hot and cold sides if you could. do you happen to have a facebook? it would be easier to send pictures that way.
Old Nov 18, 2015 | 01:49 PM
jmm98LS1's Avatar
Here's the best ones I can find of the hot side.
Here's about the only one I can find that shows most of the cold side.
Old Nov 18, 2015 | 02:51 PM
coltboostin's Avatar
Twin On3 Billet 67's here.
Plenty of fun on the street. 5.7L 850+whp at 23 psi
You can see how it spools here.
Rolling out of the hole- 16psi up top
Old Nov 18, 2015 | 07:19 PM
  #32
oscs's Avatar
Twin 66/65's on 370ci here
Old Nov 19, 2015 | 10:17 AM
  #33
stang_kllr's Avatar
Damn nice work man. thanks for the pictures. Gives me an idea on how I want to do mine.
Old Jul 4, 2018 | 11:00 PM
  #34
4doortypels's Avatar
Magic280z - YouTube
what power did that makes
