TT-99C5 car cutting out @ 4,500 RPM
Ok I think i see whats going on here. The 2 codes your throwing now are the o2 bank1 sensor1 and bank2 sensor1 insufficent switching. So both front o2's. Do you still have the rear o2 sensors? How far from the turbos are the front o2's? if there to close to the turbine outlets they will burn out pretty fast. I'd think they need to be atleast 2-2.5ft from the turbine discharge
My guess would be that both your sensors are bad and the car is going into some type of speed density mode when the computer throws the 2 codes. Thats whats causing the loss in power. Hook up a scanner and watch to see what the o2's are doing.
