Procharger buddies please help . At a loss here.
I'm working on getting the procharger supplied hard line run to the bypass valve. Right now I have the small 1/8 inch vacuum line I had used with my procharger pro flow valve.
I just don't believe it belt slip. The belts a fleet belt. It's tight and the tensioner is tight on it.
Thanks man... Second time around is always better
So the next step was getting a good vacuum source for the 1/4 inch hard plastic air line .I tapped into the brake booster line and tested it out this morning.
I did a second gear pull as my tuner said to try and it held right at 9.5 lbs ,l i tried this twice and it holds boost until i let off or shift.
I am going to try once more tonight on the way home from work to be sure but i think the race valve was opening up .
Now the question is since i have a new belt and the tensioner is tight should i take the procharger back off and put the 3.0 pulley on from the 3.4 i have now ?
I also had a problem losing boost, a pipe would pull out of a coupling, and when I let up the pipe would go back in, so I didn't see it-on a dyno I could see what was happening
MORAL OF THE STORY , IF YOU HAVE A RACE VALVE GET A DAMN GOOD VACUUM/BOOST SOURCE.
Im going to take the 3.4 off and put the 3.0 back on and hope to make about 550 out of my stock ls1 . Im looking for 120+ trap speeds .
So glad i didnt just send the procharger out to be upgraded and then would of had this problem after i didnt want to have it upgraded .
On a side note, I kinda thought the race valves spring pressure was only to get the valve to close at 0 psi. Once that happens the blower can actually start making positive mani pressure and send it to the race valves diaphragm via the vacuum line. This positive air pressure coupled with the springs mechanical pressure helps to keep the valve fully closed against opposing forces. If that makes sense.
Wish I read through this thread earlier as well.
Was the 1st thing I thought of when I read through the first page of thread.
I sent in my D1SC to be inspected because I was selling off my kit to build a Turbo setup. They found the seal was leaking and threw a new one in there for no charge.
It was like $75 total plus shipping to and from.
I'm glad you figured it out though. At least you're all set now with a good head unit that's ready to roll.
At home depot in the pipe and fitting aisle they have 3" pipe stoppers. They are black and red with a hand turn at the top to spread the black rubber to.make a seal in the pipe your testing. I got two of those and a bike tire air valve
I'll get some pics.
I have a hose from each valve cover to the can , so two ins on the car , then the pcv valve out to the intake manifold . Then the left over valve cover port on the pass side goes to a barb in front of the procharger .
Then the port on the tb is capped . i have a stock throttle body .
But that's how i was told to do it . I also had the option to block the one port on the drivers side , the rear passenger and use a larger single line from the oil fill cap to the can . Then all the other stuff is the same .
99 formula , manual trans , built rear . p1sc1 , ls6 intake , headers and full exhaust , water meth injection , btr 660 springs , hardened pushrods.
The car was fine the last two years with 3.5 inch dual intercoolers. Alternator went bad in October so since i have a sdce tensioner and its a pita to work with so i decided to go to a fmic and drop to a 3.0 pulley and go to 50 50 methanol and water from windshield washer fluid .
So i bring the car to the tuner last week , he calls it makes 6 lbs and 450 hp , two years previous it made 499 hp .
I get the car and pressure test the intercooler and piping . I have a leaky intercooler . I buy a new eBay intercooler and install it , pressure test it all again and it holds 18lbs .
At this point my tuner thought the procharger needed to be freshened so i sent it out since it was leaking from the seal . Procharger changed a seal and i think thats it , to the tune of $468 bucks .
So now i put it back in bring it up last Sunday , he calls Monday no power its belt is slipping . Okay so i pick it up retension the sdce to 20 and bring it back up that night .
Tuesday he calls and its still slipping made 6 lbs first pull then 2 each time when it was hot .
So i go it on Tuesday , order a new gates green belt , get pissed and want the car to just work so i put the 3.4 pulley back on and a 51inch belt .
51 inches and a 3.4 is where i made 499 and 9lbs at 6200 2 years ago.
The belt is so tight i needed to spin the engine over by hand to thread it on .
Thats just how it was two years ago .
So Thursday i get the belt on , retension the sdce to like 22 , i bring it up Thursday night and he dynos it today .
No go i made 5 lbs of boost or 4 at 5500 and then it tapers to 1 lb at 6400 .
He thinks no belt slip along with me bc the belt is a gates fleet belt , its wicked tight and it makes 5 lbs each time at 5500. But always tapers to 1 at redline .
He took the vacuum source off the big red race valve so all the air would go to the engine and same thing . So like i assume that's good too.
My tuner swears its the procharger , but procharger says that's not possible , it must be belt slip . But be both feel its not belt slip . It didn't slip two years ago with the 51 belt and 3.4 pulley .
Where could i be losing boost , he said he checked all the joints with soap and i use t bolt clamps at each connection .
He said he has seen first hand two p1sc1 have boost issues and get upgraded to d1 and then be fine . Procharger assures me that its gear driven and as long as its spun it makes power.
So he wants me to send it to procharger to be upgraded , i just dont think its possoibe it could be back and it cant be belt slip . What the hell else can i check . Im freaking lost and still havent floored the car this year.
What is the pipe size are you using? I bought a front mount from eBay, I used 2.5 inch piping and I made no boost. None....
I took off the front mount and mounted my 3.5 inch coolers, back to normal man.
Here is the deal, you're dual intercooler kit has two 2.5 inch piping, the area of flow is twice that than a single 2.5 inch pipes. To equal the area of the stock daul 2.5 inch pipes, you need a single 4 inch pipe. I know people use 3 inch pipes, which is ok, but still not the same to the combined area of flow, for the daul 2.5 inch pipe. Cross sectional area is important.
The front mount I bought, mounted under my air dam, it fit like a glove, it was awesome actually where I mounted it, and I used a single 2.5 inch pipe. And I got no boost. None... It killed my car.
Also check for holes in the hoses. I had a GN, I could not figure why it could not build boost for weeks. Then I found a hidden hole in one of my hoses...
This is why I am against a frount mount that uses a single 3 inch pipe, even though I know others don't have problems. Procharger engineered the system like that for a reason. To macth the flow capability of the two 2.5 inch pipes, you really need a single 4 inch pipe. Do the math, cross sectional area formula. 3.14xR^2 .
The combined cross sectional area of two 2.5 inch pipes is 10 in^2, for a single 3 in pipe is 7 in^2 and for a 4 inch pipe is 12 in^2..
By going to a single 3 inch pipe, you loose 3 in square of area.
I took fluid dynamics, it takes a lot of force trying to force air through an inadequate cross sectional area. Again, even though others don't have problems with a 3 inch pipe. However you do loose 3 in square of cross sectional area.
