Thoughts on Turbo Drain
Old Jul 8, 2015 | 09:56 AM
stevieturbo's Avatar
Originally Posted by oscs
I would agree only if he could take the car out and test it in the stripped down version that it is. If he had months of building still ahead of him and he was building the rest of the car off of the placement of the turbo i would re-do it.. In the end it would all depend on how hard it would be to go back in and raise up the turbo.
If it didnt work, and everything was fabbed and fitted together well....and it did give trouble. I'd just stick a scavenge pump onto it.
Old Jul 8, 2015 | 10:26 AM
oscs's Avatar
As would I but he clearly stated he has zero interest in adding a pump and would rather cut up and redo the hotside before he added a pump.
Old Jul 8, 2015 | 10:44 AM
Doesnt mean he cant/wont do it if it's the best/neatest solution.
Old Jul 8, 2015 | 08:03 PM
RCHipps21's Avatar
Yeah, scavenge pump is out for sure. At this point it isn't worth chancing. I was going to wait until everything was completely in before I ran DP and put WG in the merge. So I think I will find a way to raise it or move it in the battery tray area. Not the end of the world.
Old Jul 10, 2015 | 08:52 PM
rpturbo's Avatar
As someone considering doing a rear mount, what is your issue with a scavenge pump? I seen you said you had a STS before. I was just planning on building a setup, and mounting my turbo as high up, under my bed as I could for drainage.
Old Jul 11, 2015 | 03:57 AM
If you get a good quality pump, there are no issues.
