MMS Pulley, Belt Snapped
Old 06-07-2004, 05:05 PM
Ed Blown Vert's Avatar
Ok, I think I found the problem. I took the whole bracket off to check everything and found out they gave me (2) 2.5" standoffs and (1) 2.4" standoff. I was using both 2.5"(Thought they were all the same size).
Since I have an auto, I was suppose to use the 2.4" on the lower standoff. (Missed that in the instructions. Opps)
But I have two standoffs for the stock idler pulley. One is longer than the other. Any idea which on to use? Otherwise I will eyeball the best I can.
Old 06-07-2004, 08:41 PM
That looks better.
Old 06-07-2004, 10:42 PM
Took it for 2 WOT passes. It stayed together. That was the problem. I also retighten the belt. Will check it again tomorrow.
Old 06-08-2004, 06:25 AM
Moderator
Black LS1 T/A's Avatar
I'm glad it appears you worked out the alignment problem. How much boost did it make for you with the 4.10 pulley?
Old 06-08-2004, 06:40 AM
I saw 6-7# when it shifted @ 6800. That is why I wanted to shift early so I can keep it closer to 5#. Till I get my 6.0L heads.
But it ran great. No KR at all.
Old 06-08-2004, 08:58 AM
Moderator
With my 422 and Heads/Cam/Headers I was seeing about 4~5 #'s at about 6400 RPMs with the 4.10 pulley.
I've done so many different combinations now, things are starting to blur.
I should keep a journal.
Old 06-08-2004, 10:21 AM
nbm00ws6's Avatar
Black LS1TA I sent you a email.
Thanks
Old 06-08-2004, 05:41 PM
Got Me SOM's Avatar
glad you got it worked out ed, you may want to pass this information onto others with ati's.
Quick Reply: MMS Pulley, Belt Snapped
