I have to say Good Bye!!!
Thanks, i will keep you posted, im sure it will take some getting used to but we shall see.
I think with heads/cam I can run just as well as the blower only but I'll probably just go with a TNT F2 or something.
i'm on the verge of buying a 28" tire but i REALLY dont want to.
Mike
MM, i never realy hooked to good with turbo either. I hooked a 1.5 a few times.
that was with a full size front tire as well.
my set up is
-batt in spare tires spot, 27x11.5-15 hoosiers running at 10-12 psi depending on the day, East Side performance adj lower control arma and pan hard rod, bmr LCA relocation kit, TQ arm last year was a BMR @-2* this year is a sphone set @-2*, 3.73 gears, steel drive shaft, BMR sub frames, tube, stock springs all around, last year was stock shocks out back hals in front, this year hals out back now. fronts are set @ drive front 6, pass front 7, pass rear 5, drive rear 4. BMR K member and a arms, and i believe thats it.
Mike
I was just trying to say that whether the car runs a number with a blower, nitrous, or all motor it doesnt matter to the people at the dragstrip. Anyone can argue which is the best or more 'manly' way to get a car down the track, it doesnt matter to me since I have tried them all several times
I may try something like PSJ down the road and try a race oriented setup but I had this blower on the car since march and I'm getting bored
is there not an engineering bone in your body or what? LOL
It isnt going to get much easier than that. If it fit, and functioned, thats proven. It sounds like you were encountering programming trouble which I will admit, from experience, is a PITA. But it is able to be overcome.
What exactly was your boggle?
Honestly I think the blower cars get about the same amount of attention as nitrous cars from most. I honestly dont care what others think though, most head/cam/stroker guys will say that FI is no better then nitrous and so on and so on - all depends on your perspective and what you are trying to do.
From a bolt on horsepower perspective with a fairly stock engine its hard to beat the ATI/Vortech setups and I prefer to have something like that on a street car. You can argue the point for days and still end up with the same arguments either way
Mike
i could have messed with it more, But it was going to be alot more work and Money, the race season is half over and i was out of patiants with it. Its time for a change.
as for atention grabber, a car hitting low 10's high 9's is attention enoph. trust me i see it all the time!
I spend a lot of time at the track and when I see a street car go in the 9s its impressive no matter what it took to get it there.
Since your car is well set up I'm sure it will run what you want with the nitrous, keep us posted.
i know how you feal though, ive thought a few times just to switch to a Big cubed nitrous set up with a T400. Im still thinking, i know in two years my set up will change significantly, but im not sure which way it will take. Either Two T63-66's, one T88-101, or a 500+ shot.
I have been screwwing with it and just dont have the patiants for it anymore. Racing is supposed to be fun and it hasnt been. so its time for a change.
Brad, I would honestly do the same thing in your shoes....actually on second thought, if I could re-do this, it would be a 69 Bird vert with twins on a sbc...with a so-called proven kit.
In 7 days I will know if this was all worth it. APE says the car will be done and ready for street car chaos.
Either way I'll be out there pulling for you and your new adventure... expecting high 10's NA after you play with it...and if yo throw 200 on it, that'll possabily one of the few 6-speed 9 sec cars. Now that I set your goals for you...go get building and let NoGo do some magic.
