Procharger guys w/ A/C
Old Aug 6, 2015 | 05:35 AM
lbm13186's Avatar
Default Procharger guys w/ A/C
hey guys so i have a questions about the a/c, i only have one fan and was wondering if it should be hooked up to the first or the second fan wiring? I have it currently hooked up the the second fan wire and it works fine but i cant get my a/c blowing cold air and i was wondering if it needs to be hooked up to the first fan wiring? I have been told in the past that the fan should kick on as soon as you turn the a/c on and that does not happen. once it heats up around 200* the fan will kick on.
any suggestions would be appreciated.
thanks
Old Aug 6, 2015 | 06:32 AM
Cool28's Avatar
Tire Smoking Tranny Blowing Director
They have a Y hookup that goes to both. So I'd say the fan needs to be hooked up to both
Old Aug 6, 2015 | 06:41 AM
Cool28's Avatar
http://api.viglink.com/api/click?format=go&jsonp=vglnk_143886106210213&key=6d 0b3ce19161e0ba3479747a05c133ed&libId=id04rs4a01000 axq000MAbov9mex0&loc=http%3A%2F%2Fls1tech.com%2Ffo rums%2Fforced-induction%2F1410848-pro-charger-install.html&v=1&out=http%3A%2F%2Fwww.ls1.com%2Fed %2Fprocharger_owners_manual.pdf&ref=https%3A%2F%2F www.google.com%2F&title=Pro%20charger%20install%20-%20LS1TECH&txt=http%3A%2F%2Fwww.ls1.com%2Fed%2Fpro charger_owners_manual.pdf
Link to pdf should have how it should be wired.
Old Aug 6, 2015 | 06:50 AM
ramairetransam's Avatar
i have dual fans on my procharger and they are wired to run as 1 .
Old Aug 6, 2015 | 07:21 AM
lbm13186's Avatar
thanks guys, guess I will go home and do some wiring tonight.
Old Aug 6, 2015 | 08:13 AM
conan's Avatar
This may help you too... https://ls1tech.com/forums/forced-in...ring-help.html
I would also recommend add a small 8-9 inch fan to the top of the Procharger supplied fan shroud.
Old Aug 6, 2015 | 02:08 PM
gccasper04's Avatar
Ive got 2 spal fans. and the way I have them hooked up is. The grey wire is not needed. The white and blue wire goes to the hot wire on the fan and the black goes to the black. Comes on when AC is turned on and then at 180 they come on.
Old Aug 6, 2015 | 06:28 PM
JakeFusion's Avatar
Super Hulk Smash
So, I haven't really looked into this as I haven't bought my Procharger yet, but if you're running the twin intercooler setup, do you need to replace your factory fans? Is the Procharger physically in the way?
Old Aug 6, 2015 | 06:58 PM
Firehawk441's Avatar
You cannot run your stock fans.
Old Aug 7, 2015 | 06:04 AM
JRENIGAR's Avatar
Pretty much sums it up, although the stock single procharger fan has kept my temps in check this summer.
