Turbo info
Old Jun 13, 2004 | 12:43 AM
SSC5R's Avatar
WARNING! Bad Seller Alert
Thanks for your help JZ 97 SS 1500
Old Jun 18, 2004 | 12:11 AM
SSC5R's Avatar
JZ 97 SS 1500, can I run the PTE 88 turbo on the TTi or QMP system? I was just wondering. Im ready to order if so. Thanks.
Old Jun 18, 2004 | 12:34 AM
eviltwins's Avatar
TTI race system I belive you can, but on the QMP kit you need to run an on-center turbo, and the PT88 only comes as tangential.
Old Jun 18, 2004 | 08:15 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Yeah the PTE-88 on comes in a Tang. housing. The largest on-center turbo is a 76-GTQ.
Old Jun 18, 2004 | 09:55 AM
SSC5R's Avatar
Do I need the bigger log? I've heard that you do and that you don't. Which one? With a 408 motor, wiil the 76-GTQ be to small and can I hurt the turbo? Should I just go with a 375ci and call it a day? Thanks guys for your help.
Old Jun 18, 2004 | 10:01 AM
LS1TECH Sponsor
Go 375 and call it a day. The 76GTQ is kind of small for a 375 anyhow, and if you plan to push BIG hp you will run into backpressure problems and you will reach the choke limit fairly quick. As for the log design, if you are stuck running a log, make it as large as possible. Running all 8 cylinders through 1 log is not ideal.
Jose
Old Jun 19, 2004 | 01:10 AM
SSC5R's Avatar
Thanks for the info.
Old Jun 19, 2004 | 01:56 PM
SSC5R's Avatar
JZ 97 SS 1500, do you think I can make over 700rwhp with the stock 346ci? I don't want to damage the Turbo buy going to big on cubic inches. As for the log who makes the biggest one? Can you make one like the TTi, but bigger? IF so let me know that way I can order the turbo and the log form you together. Thanks for all your help.
Old Jun 19, 2004 | 02:04 PM
LS1TECH Sponsor
Yeah you can easily make 700rwhp with a 346ci. As for the log, no I don't make any, but we/PTK are working on a LS1 single turbo system, will utilize full headers.
Jose
Old Jun 19, 2004 | 02:09 PM
SSC5R's Avatar
If you don't mined what type of motor should I build? You know heads, CR, parts ex...OR if I can give you a call. Thanks.
Old Jun 22, 2004 | 10:06 PM
SSC5R's Avatar
Okay, I need to bye a set of injectors and fuel pump, which ones should I get. I going with a 348 for now. I will be going with the Turbo 76GTQ. And it will alky injected. Thanks.
Old Jun 22, 2004 | 10:42 PM
  #32
LS1TECH Sponsor
The 76 GTQ and 60 lbs motorons will do the trick.As for fuel pump dual Walbro 340's.
Jose
Old Jun 22, 2004 | 10:49 PM
  #33
slyws6's Avatar
how do you rig the dual 340's to work together and get them to fit, require tank modifications?
-Sly
Old Jun 22, 2004 | 11:02 PM
  #34
SSC5R's Avatar
I would like to know aswell
Old Jun 23, 2004 | 04:43 PM
  #35
SSC5R's Avatar
Where can I get the Motrons Injecters and how much? Thanks.
Old Jun 23, 2004 | 05:55 PM
  #36
LS1TECH Sponsor
I think racetronix use to do a dual 340 setup.
I carry Mototrons also....
Jose
Old Jun 23, 2004 | 06:12 PM
  #37
SSC5R's Avatar
Okay, sweet I'll get them from you then.
Old Jun 23, 2004 | 06:15 PM
  #38
SSC5R's Avatar
what kind of power is the 70mm good for to the wheels?
Old Jun 23, 2004 | 07:22 PM
  #39
nick y's Avatar
Originally Posted by eviltwins
Why? Go take your stock aluminum block or an iron block if you want to, get some new pistons and take the block out .005 or .020 over or whatever you want, throw some good 6.125" rods in there, and enjoy. A 348 will make all the power and torque you want, it will be MUCH cheaper and MUCH easier to drive on the street than a 400+ inch turbo motor will, and you will probably end up making more power. A 427 or a 408 is going to be moving a ton of exhaust flow, so you could potentially be choking off the exhaust wheel before you have maxed out the compressor side of the mtoor.
Just my 2 cents, i'm running a 360" motor (4.1" bore and 3.4" stroke) and at 775 RWHP it's actually driveable on 17" BFG drag radials. If this were a 400+ inch motor with a 4" stroke, it would be making well over 900 torque to the ground and would light up the tires if you gave it any throttle.
thats what i plan on doing!!! you dont need all those cubes!
Old Jun 23, 2004 | 07:25 PM
  #40
nick y's Avatar
Jose
JOSE THE RETURNLESS fuel on my 03 c5 with my 650 to 700 goals will be a problem? i heard racetronic is coming out with new return system to cure?
