Turbo info
Old Jun 24, 2004 | 01:42 PM
  #41
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
SSC5R, the MP 70 will make ~840-850 crank hp. Depending on your drivetrain losses, you would see a peak of about ~675 with an auto and ~720 with a stick.
Nick, the 03 Cobras are making that much with a returnless system as well and 60# mototrons.
Jose
Old Jun 24, 2004 | 03:29 PM
  #42
MYTURBOT/A's Avatar
Originally Posted by JZ 97 SS 1500
SSC5R, the MP 70 will make ~840-850 crank hp. Depending on your drivetrain losses, you would see a peak of about ~675 with an auto and ~720 with a stick. Jose
Yea but at how many PSI?
Old Jun 24, 2004 | 03:40 PM
  #43
LS1TECH Sponsor
That will all depend on the setup of the motor. It will vary with cubes, rpms, cam shaft profile, and head flow #'s. Just for a "ballpark" figure, most of these T4 turbos on a large cube motor will only put out around ~20psi. The small T4 units will spike to 20psi and then will bleed back down as they reach the choke limits.
Jose
Old Jun 24, 2004 | 07:01 PM
  #44
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by nick y
JOSE THE RETURNLESS fuel on my 03 c5 with my 650 to 700 goals will be a problem? i heard racetronic is coming out with new return system to cure?
http://www.racetronix.com/Racetronix-C5-Reg.html
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Jun 24, 2004 | 10:31 PM
  #45
SSC5R's Avatar
WARNING! Bad Seller Alert
Thanks guys for the feed backs
Old Jun 28, 2004 | 09:22 PM
  #46
SSC5R's Avatar
JZ 97 SS 1500, would you be able to give credit on the Garett 70 turbo that I have now? I was thinking in a Solid cam 242/232 670/670 @114. I have a set of 1.7 Jesel's. See I bought everthing to convert to a solid roller. Up to what RPM can I spin these 76 turbo to?
Old Jun 30, 2004 | 06:50 PM
  #47
SSC5R's Avatar
What do you think JZ 97 SS 1500?
Old Jul 1, 2004 | 03:26 PM
  #48
LS1TECH Sponsor
As far as the T-70, right now I can't take anymore turbos in. I'm knee deep in turbos right now that are coming in. As for a solid roller, its nice to have a solid setup. RPM wise, their really is not set rpm limit engine speed wise for a turbo. Its not like a blower that you can overspin.
Jose
Old Jul 6, 2004 | 10:14 PM
  #49
SSC5R's Avatar
I would like to go with the T-76 but I'm not sure if that's a good idea. I would like to wait for the system that you are coming out with. Could you put me down for the ist one that's coming out. I would like to go with the T-88. So how soon do you think the system will be ready? I can't wait for to come out. Let me know jose. Thanks.
Old Jul 6, 2004 | 10:42 PM
  #50
LS1TECH Sponsor
Well right now, looks like Aug 9th the donor car will go in, if the donor car comes through.
Jose
Old Jul 6, 2004 | 10:59 PM
  #51
SSC5R's Avatar
If you need a 2nd donor car let me know. I don't care how long you need it for.
Old Jul 7, 2004 | 12:56 AM
  #52
LS1TECH Sponsor
I will put you down on the list for contact if the others on the list drop out.
Jose
Old Jul 7, 2004 | 03:46 PM
  #53
SSC5R's Avatar
Thanks man
