CBR 8.65 and Aster Bracket users step in .
Old Aug 25, 2015 | 09:25 AM
ramairetransam's Avatar
Default CBR 8.65 and Aster Bracket users step in .
Im going to get an aster bracket from my sdce . Reason being is im trying to make a bunch of power and boost with the stock heads and cam . So i got a 3.0 pulley and it belt slips now . Since i only rev to 6k i need a real small pulley
So with the aster im going to get the 8.65 crank pulley and either a 3.6 with will give me the same rpm or a 3.8 since its a known belt length .
Id like to do the 3.6 but no one has come forward with the length i would need.
Hows the ls2 water pump clearance with the 8.65 crank pulley?
Any thing i should know before going to the aster ??
Old Aug 26, 2015 | 04:36 AM
Husker98's Avatar
Ever think about getting the LS2 wp and running a CBR 8.65" pulley with the sdce setup?
Old Aug 26, 2015 | 04:58 AM
It won't work. Even the 7.625 procharger one won't work. Stuff is spaced differently
Old Aug 26, 2015 | 05:18 AM
Husker98's Avatar
That's to bad I was hoping to go that way for my sdce setup if needed
Old Aug 26, 2015 | 03:26 PM
Mike 02T/A's Avatar
Maybe get a boost cam vs stock cam. How much power are you trying to make with stock heads/cam? I just dont see you getting enough rpm gain to make it worth the money, unless the belt slips like crazy!
Old Aug 26, 2015 | 05:47 PM
Husker98's Avatar
If you already have the springs and pushrods find a good used cam. The cam i got and similar are adding 100hp to their already boosted setup
Old Aug 26, 2015 | 07:49 PM
i already have btr 660 springs and aftermarket pushrods , the car made 572 574 and then 572 then after that at some point i started getting belt slip . 572 is good for me . But if i had a cam the 3.4 would be fine since i would rev to 6500 . Other than that its been fine but i tried to go to small on a belt that had slipped before . So many if i put a new belt on with the coated 3.0 it would be good but im not going to risk it . I want to push this engine but only rev to 6k .
Old Aug 26, 2015 | 08:31 PM
conan's Avatar
Here's my $.02
As said above get a cam in that thing. Save your $$$ on the ASTER for now but do the LS2 water pump since the coolant has to be drained and water pump has to come off for a cam. Go back to the 3.4" blower pulley and spin the motor to 6,500. Then if you still get slip the ASTER can go on with out coolant mess again. A mild blower spec cam should be good for 50+ hp vs stock cam on a blower car. Get ready to feed it more fuel too.
Old Aug 27, 2015 | 05:42 AM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Thanks for the order Jeff, I appreciate it. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Old Aug 28, 2015 | 01:53 AM
Inspector12's Avatar
TT-TECH Veteran
I don't know where you guys come up with this ****. I ran the SDCE set up with an LS2 WP W the big crank pulley, and had no issues! I did get the Aster bracket, I was one of the first ones with it. It did work fine, I can't tell you 100% if it was any better than the SDCE set up. Its definitely engineered way better. The tensioner is a little weaker than the one SDCE uses. But good luck with your project.
Old Aug 28, 2015 | 07:44 AM
JRENIGAR's Avatar
According to Bob's post it looks like you have already spent your money, however, another option would be to sell the p1 and upgrade to a d1. That way you could use a larger pulley and actually achieve more hp while avoiding belt slip and lowering IAT's. I sold my p1 and put $600 with it to get a used d1. IDK what your elevation is but my setup with the sdce 8 rib kit and a 4.5" blower pulley nets 10-11#'s @ 6500rpm. Before I backed it down a 4.0" pulley made 15#'s. Just some food for thought.
Old Aug 28, 2015 | 09:46 AM
conan's Avatar
What size crank pulley did you run with the ls2 water pump ?
Old Aug 28, 2015 | 10:00 AM
as far as i know no one has run the 8.65 with the sdce , and not even the 7,65 works because of a different offset .
Old Aug 28, 2015 | 11:00 PM
Husker98's Avatar
How much boost were you making with the 3.0 & 7.25 pulleys?
Old Aug 29, 2015 | 09:23 AM
13.8 lbs at 6000 or 6100
It was spinning the p1sc1 to 60000
Old Sep 25, 2015 | 06:20 AM
since im getting the ls2 waterpump what thermostat housing do i need? im pretty sure i have the early style ls1 housing . Will that work with the ls2 pump .
So if i do need a new housing and 160 stat can someone point me to a link or part number . thanks.
Old Sep 25, 2015 | 06:26 AM
LS1Tech Sponsor
http://shop.brutespeed.com/Mr-Gasket...asket-6367.htm
You will need one like what is in the above link. Thanks. Bob
__________________
Old Sep 25, 2015 | 06:41 AM
so then to make this perfectly clear , i need a late ls1 style housing then ?
Old Sep 25, 2015 | 06:52 AM
LS1Tech Sponsor
You just need a late thermostat, you don't need to replace the housing. Bob
__________________
