Need help Reading Vac/Boost Gauge
Old Jun 8, 2004 | 11:59 AM
IRVINEWS6's Avatar
Default Need help Reading Vac/Boost Gauge
I just installed a vac/boost gauge. When I floor it, the guage goes from vacuum to boost; however, as I roll through the gears, it never goes back into the boost section. Shouldn't it go back into boost in each gear?
Also, my vacuum at idle is 15 n.hg. Is that normal?
Thanks
Old Jun 8, 2004 | 01:03 PM
ChevyNo1's Avatar
Yes, it should go back into boost in each gear as you floor it . . . and that reading at idle sounds normal.
Old Jun 8, 2004 | 07:40 PM
IRVINEWS6's Avatar
Thanks. I will go through the gears again tonight and see what happens.
