Need advice 88mm 408" LS3
Call up Tick or LJMS if you want a custom specced cam. Either of them will give you something that will work better for your combo than any shelf cams.
Rear gearing depends a lot on tire size, but longer gears usually help with a turbo. I run a 3.55 rear gear with a 28" tire with a 4L80e trans (think TH400 gearing).
By all means run it if you have it and just want too. How fast are you looking to go and whats the budget?
To answer your question, no I have never used that turbo but it makes great power on small motors.....like 300" and below.
