New PB with Precision PT8285 CEA
Old Sep 25, 2015 | 05:02 PM
sweet99ss's Avatar
Originally Posted by willizm
How much boost and et was MM pushing and what was the motor configuration. I've got a little more in it I can go. I only hit 20psi but should have enough to crank up to 23psi before my pumps start to dive hard. Dual 340's ftl.
So do you plan to take it to the track again with more boost?
Old Sep 27, 2015 | 10:49 PM
HolyShiznit's Avatar
8.73 @ 159, 3815lb car on 17" drag radials. 6 liter with a PT88, 1.35 60'. 23psi but he said it was inflated since it was through a ls6 intake/ls1 tb. He later switched to a drop in 91mm housing that gave him a very minor bump in power, I think he said it was worth 3mph in trap.
Old Sep 28, 2015 | 04:54 PM
Spectre86's Avatar
3mph is a lot when your trapping 160. the 91 spooled quicker too. I think it picked up 100whp
Willizm,
Suspension
Viking DA Coilovers(MWC) all 4 corners
BMR Lower A-Arms and Turbo Kmemeber
UMI LCA's, Torque Arm, Panhard Bar, SFC
MWC Drag Bar
How much playing around with the suspension did you do? 1.2 60ft is a hell of a launch.
Old Sep 28, 2015 | 04:58 PM
willizm's Avatar
Willizm,
No a whole lot honestly. MWC gave me some baseline settings to start with and I cut a low 1.3. I played loosened up the fronts a touch and ran a 1.28. I left it at that.
Old Oct 3, 2015 | 03:37 PM
Beanslsxnova's Avatar
Where did you get that button on your steering wheel?
Old Oct 3, 2015 | 08:06 PM
willizm's Avatar
http://www.jegs.com/webapp/wcs/store...=&pgGrp=search
That's the one I use
Old Oct 4, 2015 | 12:33 AM
Honeycutt's Avatar
Not too damn shabby. I've seen that turbo do well on 2J's, and I always figured it would do nicely with an sub-350" engine.
Old Oct 4, 2015 | 07:15 AM
willizm's Avatar
If you know 2j's pretty well then you probably know Sharkey's blue supra. I bought this turbo off of him. He had this turbo and made some serious steam out of it. I'm not even pushing this thing hard.
Old Oct 4, 2015 | 07:30 PM
Honeycutt's Avatar
Aha, yes I do know John. I noticed that you were from Chitown, but I wouldn't have guessed that.
Yeah, from what I remember he made good power, those turbos are powerhouses.
Just don't buy his 6870 lol, it may not work as good.
Old Oct 4, 2015 | 07:42 PM
willizm's Avatar
Yeah Johns a pretty good friend. I was actually trying to sell the turbo for him but ended up borrowing it to see if it could fit. Well it fit really well so I ended up keeping it.
