LS2 Turbo questions.
Stock LS2
Twin turbo (space & location constraints), Air to air.
Daily capable Street tune (93 octane)
Will address fueling as necessary (injectors,pump)
Eventually I'd like to cam and build the bottom end (stock cubes) maybe lower the compression and hit it a little harder, so I'd like to keep "room to grow" a factor.
I see the APS GTO twin turbo kit making 545whp on low. The turbos look like like fairly ordinary T3 sized turbos.
Ive been considering the garrett GT3076R (also available with a larger .82 housing.) Does this seem like a good choice? What would be a comparable choice from say precision?
I have been looking at this page, but the bottom is all messed up and illegible...is it just me?forcedinductions.com/help.htm
Stock LS2
Is it even going into a GTO ? Are you using parts from an existing kit ? How much space do you even have for turbos etc ? The APS kit uses small turbos for a couple of reasons...firstly it was intended as a simple bolt on mild upgrade and then there isnt much room in the first place.
Precision do direct replacements for the Garrett's, or they'd do many of their own equivalent size options. A/R will depend on whether you want T3 or T4 flanged units.
Not GTO, but first gen CTS-V. Similarly I'm looking to mount in the catalytic converter location, so physical size is a considerable constraint.
Horsepower.... I mean the more the better, but given the restraints of stock bottom end, stock compression and 93 octane....I'm trying to find a sweet spot for these limitations. Would like to be 600whp..with some head room for meth and eventually built motor on....but still need drivability....... So really to be honest, I am more flexible with the output....I'm thinking 1200 is possible with 2 gt35s.......not sure how much larger those are than the GT30Rs (x2 good for 1000?) All the meanwhile I want to keep it safe enough to not break a ringland.
I understand the fundamentals of turbocharging...and how two turbos will have different characteristics (response/output) but when it comes to selection for a given engine I have practically zero first hand experience.
Relocated alternator<br/>
