Turbo upgrade! TC70 to 6766 to small?
Get the larger turbos, or at least larger exhaust housings, to reduce backpressure.
Either way, you will probably notice the biggest difference, in both power and efficiency, by installing the afr heads, regardless of which turbos you choose.
The heads will make a huge difference, and I think they would be a smarter choice, over new turbos.
If you want an exucst to throw money at the car, have at it. But, I would try with what you got first.
stevieturbo 6766's will easily do 1000, and then some.
For only 1000hp, they are not too small.
Are you wanting less lag than the tc70 currently has?
However, small turbos create more back pressure than larger turbos, and back pressure is in no way conducive to efficiency.
So, in theory, you want the smallest turbo(s) that will achieve your goals AND give you the least amount of back pressure. Sometimes you have to step up a size on the exhaust housing to get back pressure down closer to 1:1.
But I think you are on the right track with retaining the turbos you already have, and installing the afr heads.
I've BW 6468's on mine on a 382. Some might say the turbine is on the small side. But certainly as far as around 25psi and to about 5500rpm I'm right around 1:1
Only over those two things does EGBP rise slightly higher than manifold pressure. But it still wouldnt even be as high as 1.25:1
At 28psi from 6-7000rpm EGBP was just a little higher. But at all times below 25psi it's around 1:1
IMO if he wants new turbos and very responsive, I'd be inclined to go smaller than the 6766's. Maybe more like a 6266 if Precision
Or for the BW either the 6268SXE or maybe 6373SXE
http://www.agpturbo.com/s300sx-e-series/
