Transplant bracketed for D1
Old Oct 9, 2015 | 03:02 PM
OmenNova's Avatar
Default Transplant bracketed for D1
I've searched a lot to no avail. If there's a previous thread or wrong section let me know. I'm swapping my 3rd gen nova, and I have a truck/camaro crank pulley with my motor but no other bracketry. I was wanting to put my alternator and power steering on one side, then a D1sc on the other. Doesn't really matter, just want brackets not mounted low. I was thinking about a set of dirty dingo brackets but at this point I just need guidance lol. Alt/PS and d1 no ac with truck/camaro pulley and water pump.
Old Oct 10, 2015 | 12:16 AM
Blown06's Avatar
8 Second Truck Club
Truck pulley is different than camaro pulley.
Old Oct 10, 2015 | 01:02 AM
OmenNova's Avatar
I'm referring to it as in 2010+ camaro pulley. Through more research I think I've found my path. You can buy a full corvette drive setup of alt/ps for $535 from jegs. That works perfectly with a Vortech passenger side setup.
Old Oct 10, 2015 | 06:56 AM
forcd ind's Avatar
When I put an LS in a chevelle, I used the corvette Procharger setup, D1SC, and corvette front drive setup, made it an 8 rib drive
You can get comp. vette front drive take off's on Ebay for around $600, come with everything
Old Oct 10, 2015 | 12:47 PM
OmenNova's Avatar
Yeah it seems corvette drive is the way to go. I had looked at the corvette setup but it seemed with the procharger mounted forward that I may not have enough room. I believe the chevelle core support and radiator is about the same as the novas though so that may fit nicely. Thanks
Old Oct 12, 2015 | 12:19 PM
Bob@BruteSpeed's Avatar
LS1Tech Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
http://www.indianamusclecar.com/
Justin May makes a bracket for the 3rd gen with an LS engine, check out the above link. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
