Good source for copper head gaskets?
Old Oct 9, 2015 | 07:35 PM
vinceI's Avatar
Default Good source for copper head gaskets?
I'm in need of some thick .080+ copper gaskets for 4.185 bore 6 bolt setup. Does anyone know a decent place that might have them. Trying to take some compression out of an engine that has .050 gaskets on it now.
Old Oct 9, 2015 | 10:55 PM
RonA's Avatar
I special ordered a set of MLS gaskets from Cometic. Took a little over 3 weeks to get them. They make soft copper gaskets in .080, and .094(along with thinner as well).
Old Oct 10, 2015 | 09:35 AM
vinceI's Avatar
Thanks, block is o ringed so I def need copper. I will give them a call. Their website leaves a lot to be desired.
Old Oct 10, 2015 | 11:42 AM
RonA's Avatar
I actually ordered mine from Brian Tooley, but it came direct from Cometic since it was an odd gasket(6 bolt 4.130 x .040 MLS). Process was pretty easy once you find the special order area.
Old Oct 10, 2015 | 11:49 PM
vinceI's Avatar
Ok, thanks for the reply. I will try them on Monday.
