Looks very nice for a home build. Nice fab work!
Performace? Should make around 700 whp around 15psi (all numbers realtive, as always!) But it should go 9's without too much toruble.
Quote:
Any chance you could post more pictures of how the turbo kit is run/setup?Originally Posted by autoaddictions
No I regret not taking more pics. Currently building a 4.8 swapped 03 myself. Not turbo this year but I've got a healthy motor, LS9 cam and 317s on it when the time comes
forcd ind
close
- Join DateSep 2007
- Locationwoodbine, md
- iTrader Positive Feedback100
- iTrader Feedback Score(7)
- Liked:292 Times in 198 Posts
Did you have to cut the floor for the 4L80E to fit-I cant remember how much raised tunnel they have
Quote:
No it's tight but it went in there. I did have to make my own crossmember.Originally Posted by forcd ind
Did you have to cut the floor for the 4L80E to fit-I cant remember how much raised tunnel they have Yeah I sure wish I could see your manifolds you built! Love your truck, that what mine is supposed to be.
im in the process of building my turbo hot side. I see you have the downpipe going down under the frame. any interference with the front tire?
Quote:
With a full size front tire it be a problem! Since im running a 4" wide front rim and a 1 1/2 spacer it has room for turning. If I had it to do again id cut the pass side lower firewall back and fab up a new panel allowing for both the crossover and downpipe to fit. It would take away some foot room on the passenger side but I think it be worth it less bends in the down pipe !!Originally Posted by m8w6r77
