Turbonetics turbos?
And by the way I was using 45 psi or higher as an example because my oil pressure is above 60 psi hot at idle. So when I used the above mentioned restrictor with the supplied .045 restrictor, it fixed all my issues. But to say it is a load of sh@t was not the case for me and the OP may not have any issues either like you. Then again, there is always that possibility. This reply just reminded me of how unfriendly this forum can really be at times.
To the OP, good luck with your build man!
"any oil pressure above 45psi will push oil past the seals" is a load of ****.
When you make false statements like that on a public information forum expect to be flamed. Don't forget that people come here to learn. Choose your words more wisely next time.
