? for people with Holley Hi rams
Old Oct 24, 2015 | 11:13 PM
dmracing's Avatar
Default ? for people with Holley Hi rams
The vacuum port off the rear. Im going to run a line from there to a vacuum block to provide vacuum for wastegate and bov. Im using 4an from the block to the accessories. But what should I run from the intake to the block, 4 or 6an?
Old Oct 26, 2015 | 03:16 PM
JoeNova's Avatar
Restricted User
I usually run -6 on mine, but I can't see -4 being an issue. Then again, I run my wastegate off of a separate reference than my vacuum block.
Old Oct 27, 2015 | 11:59 AM
3 window's Avatar
Agreed with JoeNova. Won't matter. It's a closed system. Once there's vacuum, there's vacuum. Use what you have. The ONLY thing I see ran into was that my map signal was a little erratic. I put a mig welder tip in the line and it calmed the signal pulsations just enough to smooth it out. This is on a stack injection (like Hilborn) manifold with a vacuum line to each port, then to a block and then to the map. You shouldn't have any problem with a common plenum.
