5.3 Nova Best to date
Old Oct 26, 2015 | 02:10 AM
ajrothm's Avatar
Awesome job Ron!
Your attention to detail and preparation shows in the results!
No doubt it has 8s in it. Another tenth off your 60' and you're 9.0s.. 2 more psi of boost and you're solidly in the 8..
Crazy performance out of a stock 5.3 with a cam.
Interesting note.. 149 @ 6500 with 3.42s on 28s. Your converter is very efficient up stairs. Mine at 151 is at 6900 ish, on 3.42/28s. I've tightened the converter twice. Maybe it has to do with the weight too. I'm 3600lbs race ready, I'm sure you're lighter then that.
Either way, congrats buddy. I can't wait to see you hit 8s.
Old Oct 26, 2015 | 06:39 AM
forcd ind's Avatar
Ron, what size injectors are you running-I have the Holley 120's, was thinking of doing an E85 tune in it and see how it ran next spring
I have the "hated" 12-1200 Dom pump, been flawless, even ran 12 #'s of
boost on just one pump, 93 Oct (forgot the fuse on the sec pump, lol)
Not sure how it would do on E85 though
Old Oct 26, 2015 | 09:30 AM
RonSSNova's Avatar
Originally Posted by ajrothm
Awesome job Ron!
Thanks Alan.
I seem to remember you predicted my vette would run a ten too. 😊
The PTC converter shows 5-6% slip up top. It really works well. It flashes to 5400 once the car leaves. And it drives around nice to boot.
I have forged internals to add over the winter. And of course need to address the fuel system a bit.
Not real sure I want a parachute though.....
Old Oct 26, 2015 | 09:37 AM
RonSSNova's Avatar
I have ID1000 injectors. According to thier data sheet, they flow 116 lb/hr at my 60 psi base pressure.
In my logs, the Holley pump is done at 77psi, and the pressure drops to 75 at the end of the run.
Duty cycle right at 100% there, but is 110% at the shifts.
I believe it's all safe, but I'm pushing all the limits.
AFR stays solid throughout the run. Doesn't mean every cyl is happy though.
Old Oct 26, 2015 | 03:13 PM
JoeNova's Avatar
Restricted User
Always giving me hope, Ron.
Old Oct 26, 2015 | 03:37 PM
HolyShiznit's Avatar
Hi Ron, it's Jon from FB. What type of PTC converter do you have? Multi-disk? I have a PTC single disk that I was going to send in to be loosened slightly. Figured I would upgrade it while it's there.
Old Oct 26, 2015 | 03:43 PM
RonSSNova's Avatar
Hey Jon. I have a no disc converter. It's a TH400
Old Oct 26, 2015 | 05:42 PM
Beanslsxnova's Avatar
Congrats man that's flying.. Make me jealous all my car does is break haha
