ebay 88mm turbo
Old May 25, 2016 | 02:03 PM
  #101
Forcefed86's Avatar
Except when you have a 4000lb car and a 250lb driver... 100hp is rather mediocre. I have to make drastic power changes to make this boat anchor feel faster. I thought it was making maybe 800 on the old turbo and the S480 would make a solid 200hp more seeing how people make 1000 even with the cast wheel S480. I thought the billet wheel would be good for even more then that really. How much more boost can it run? Seen people pin the gates and it makes 29lbs. I don't have much of a wastegate as it is, single Tial 38mm.
Have you calculated the trans/converter slip? Because you didn’t see/feel a larger gain at the wheels doesn’t mean it’s not there either. That’s a ton of boost you’re running and I realize your vehicle is heavy. At such a heavy weight you are asking a lot of that trans/converter. If you’re not picking up a steady amount of power with each added LB of boost there is another problem. Throwing more boost larger turbos at it might not be the answer to making more power.
Look at Stock48’s full size 4x4 pickup going 9.73/140 at a 4860 race weight with the small cast GT76 T4 turbo around 20lbs.
I've seen 5.3's make 250-275whp NA then go over 1000 on 25psi. According to theory they should only make 750-825.
It’s not a theory, it’s a fact. Can’t defy physics. Double the air density/fuel it doubles the power. (minus parasitic/heat losses.) Looking at chassis dyno readings there are too many variables/inflations. Strap that same engine to an engine dyno it will cut out a ton of variables and tell a different story. I'm not doubting you saw an indicated 250-275hp NA and an indicated 1000hp at 25psi. I'm doubting those indications were correct.
Old May 25, 2016 | 02:38 PM
  #102
SLOW SEDAN's Avatar
I have looked at it and I asked the manufacturer what I can do to reduce slip which is why I went from a 2.92 to a 3.45 gear to make the car feel lighter to the converter. The car picks up as I add boost for sure, fuel flow goes up and the car was running 10's on lower boost and as I turned it up ET went down and trap speed went up. Problem is I'm not content with 9.anything, needs to be faster.
I'm not saying its not making more power, it obviously is... fuel flow, IDC, etc is all up and it rolls down the road ok. I'm just saying it wasn't the OMG increase I was expecting. I'll see how it does at the track and go from there.
Old May 25, 2016 | 08:25 PM
  #103
Forcefed86's Avatar
Righto I'm not saying I have a clue whats going on with your setup. Only that heavier setups have trapped similar times with less boost on a smaller turbo. Meaning maybe all that power isn't getting to the ground, even with the old 88mm setup. Is that a 6.2? or a 6.0? What kind of slippage were you seeing with the 88?
Old May 25, 2016 | 08:41 PM
  #104
LT1PWRD's Avatar
Now I see why people go twins with cheaper turbos, not many singles out there under $2000 that can move big air.
Question, do you think a pair of S366s would out do that s480?
Old May 26, 2016 | 07:27 AM
  #105
SLOW SEDAN's Avatar
Lol 6.2... I have a junkyard 5.3L with about 170k miles on it. About 15% from what I could tell but they said that was due to the gearing so I'll have to see what it is now.
They probably aren't running super safe tunes... Or maybe they are I have no idea but mine are pretty soft to keep stock junk together.
Old May 26, 2016 | 10:39 AM
  #106
Forcefed86's Avatar
Think stock48 has put more miles on his SBE stuff than just about anybody on the SBE lists, Esp. that truck. Won drag week with his nova as well. And manages to make more power than any of them. Don’t get me wrong I can’t get my car to do anything near what his does and I’m lighter weight. Just mentioning it because I’m sure there’s room for improvement with that combo at that boost level with the S480.
15% Slip is nuts BTW. I’d call up Dusty at PTC and get that taken care of before touching anything else. If the company knew the gearing/tire size/weight when they built that converter there’s no excuse for 15% slip. If they are blaming the gear, I’d drop them in a heartbeat and go with a proven company that knows how to setup a turbo converter.
For example I was under 4% thru the traps with my PTC unit with a 29” tire and 3.25 gear. Can make 9-10lbs in about 2 seconds on the T-brake as well.
Old May 26, 2016 | 01:40 PM
  #107
coltboostin's Avatar
And trap mid-high 160s', backing up their dyno numbers.
But-I've went down this road with these guys. Although I agree with you, and there is a plie of evidence to show the dyno/trap is accurate, the internet physicist will claim you are wrong. There is no winning this argument.
Old May 26, 2016 | 01:49 PM
  #108
Forcefed86's Avatar
I'd rather be an internet smartass than an internet dumbass...
Old May 26, 2016 | 03:37 PM
  #109
sbcgenII's Avatar
Who's trapping mid high 160s sbe with any weight? Stock48 and who else? I don't think stock48s motor NA makes anywhere near 275rwhp either.
Old May 26, 2016 | 04:08 PM
  #110
SLOW SEDAN's Avatar
I wouldn't blame them just yet as it was spec'd back when I had the 7675 and I told them I would be running a 3.45 gear I just haven't got around to installing it until now as I waited for the stock diff to give up smoke. It's an FTI TH400 and converter, worst case I send it back while I have the engine out.
I tried to get it down the track today but ran out of fuel pump... So I'll have to fix that before I give it the beans again.
Old May 26, 2016 | 09:11 PM
  #111
Forcefed86's Avatar
Couple on the top 10 list here. I'm sure there are others, not sure the list is up to date...
1)silver_82 8.19@167.97 LM7@31psi @3250lbs
2)mxguy1286 8.29@164 4.8L@29psi @3000lbs LS Notch Fox body- Auto
3)skinnies 8.65@167.9 JY 5.3 @2600lb
4)Stock48-8.22@164mph-LQ4@23psi 3300lbs (Best ET)
5) ScreamingL 8.65@163.9 LY6@24 psi 3400llbs w/ driver
6) Dudeman-8.6@161mph trap-LY6 @3100lbs
7)-Forcefed86 -LC9-8.93 @ 159.24 at 24psi 2850lbs S476
Old May 29, 2016 | 07:01 PM
  #112
Its not. I have admittedly not kept up with it over the last month or more, but there is some great data on there
Old May 29, 2016 | 10:10 PM
  #113
sbcgenII's Avatar
What are we paying you for. Get to work.
Old Jun 8, 2016 | 08:55 AM
  #114
SLOW SEDAN's Avatar
Took the S480 out for a spin to compare to the On3 88mm... not a huge difference. I guess the S480 is good for an 80mm but still a little lacking to me. I was expecting shock and awe according to the people claiming 1000+whp with it.
S480 spools a little faster roughly 200-400RPM but doesn't seem to make a ton more power up top. Looking at fueling On3 at 26PSI vs S480 on 27lbs is maybe 100hp difference. I guess that's a decent amount but I was expecting more the way people worship these things.
I'm gonna go ahead and retract the above statement!
Turns out the problem I had after installing the S480 was lack of fueling, causing it to feel like a turd. New turbo caused me to run out of pump and it was going lean (thank god for E85 it didn't blow up!). I installed a Magnafuel 4703 to solve that problem, now on 22lbs the S480 is a damn rocket compared to the old setup. Its making a lot more power now!
Seems to be a lot less backpressure on the T6 housing as well, I can wastegate down to 14-15lbs to do boost by gear in 1st, then give it the beans up top. I have boost ramping in fairly slow and it still blows the tires off from highway speed (used to dead hook on the 88) so I'll need to slow the ramp a little more for street traction. It certainly spools faster then the 88mm, it cracks into positive pressure before I can get my foot down comes on at 2700RPM.
So while the ebay 88 had a good run the S480 is certainly an upgrade. Took a couple days to sort out but now I'm happy with my purchase!
Old Jun 9, 2016 | 04:37 PM
  #115
Fat Jesus 808's Avatar
Finally dynoed on my PT88 last night. 710/620 on 17psi (dyno reads .5high), through an unlocked 4L60e, ford 9", and 28" drag radials on 92 octane and no Meth
Old Jun 10, 2016 | 10:17 AM
  #116
Yours was a true PTE MFS turbo correct?
Your area under the curve is impressive!
Old Jun 10, 2016 | 04:23 PM
  #117
Yeah, True PT88 MFS i bought from Huron Speed.
Old Jun 10, 2016 | 04:24 PM
  #118
Friends PT88 cast wheeled car made 823/701 last night on 110 octane @ 23psi unlocked through a 60e and 10 bolt
Old Jun 10, 2016 | 10:32 PM
  #119
Not terrible!
Do you guys have the same turbine wheels?
Old Jun 14, 2016 | 02:16 PM
  #120
I believe they are the same turbine wheels.
