ebay 88mm turbo
Turbo LS Mustang China 88/83 turbo - YouTube
Edit: These were the specs on youtube...
710.9 HP, Stock Rod/Piston 6.0L with sqaureport speedmaster heads, 224/230 cam Home brew 700 double pumper, VSracing PT88 clone, th400 with 3.55's and a 28x10.5 tire. 14lbs of boost on a Mainline Dyno
Would be great to have some track trap speeds to back the numbers though. We’ve all seen high HP dyno numbers not match trap speeds for one reason or another.
The guy that just took the stock LS 4.8 record is a great example. Dyno’d “only” 850ish whp, yet he runs 8.3X trapping 162 @ 3000+lbs. Which some 1200whp dyno cars can’t seem to manage at similar weights.
if you want more power you need to get a bigger turbine wich you cant really get a china turbo wit ha larger turbine
this is one of the largest turbine red sea express's you can get
otherwise i goto forced inductions and get a 92-96mm turbine in one of many flavor's
