ebay 88mm turbo
Old Nov 26, 2015 | 11:54 PM
  #41
Fat Jesus 808's Avatar
Im putting the new PT88 MFS on my 5.3 this winter. Had a 7475 on it last year.
Old Nov 27, 2015 | 10:13 AM
  #42
coltboostin's Avatar
Yes its the 83mm turbine and I'm looking to be at the track next week.
Nice Set it on kill!
Fancy!
Old Dec 4, 2015 | 11:59 PM
  #43
SLOW SEDAN any track updates?
Old Dec 5, 2015 | 07:31 AM
  #44
SLOW SEDAN's Avatar
Yes actually!
With the 76mm I got a best of 139.46MPH after switching to the 88mm that increased to 144.97MPH! Thats same boost level, same timing, just tweaking A/F for the increased airflow.
With similar 60' I got a 9.80 out of the 76mm, ET dropped to 9.64 with the 88mm.
Old Dec 5, 2015 | 07:52 AM
  #45
Guard dog's Avatar
Yes actually!
Great info. What boost level?
Old Dec 6, 2015 | 08:47 AM
  #46
Yes actually!
Nice. Great review! Any plans to set it on kill?
how is the "lag" on the street on comparison?
Old Dec 6, 2015 | 08:50 AM
  #47
rotary1307cc's Avatar
Looks like a copy of the old TV 7 blade 88 compressor
Old Dec 6, 2015 | 09:16 AM
  #48
SLOW SEDAN's Avatar
My wastegate is 17-18PSI and I run it 21-22lbs on the controller. The gap between the 76 and 88 seems to stay consistent as boost rised. Under conditions the 76mm would run 136MPH the 88 ran 141, when the 76mm would run 139MPH the 88 ran 145.
I went to give it hell and blew the diff out of the car! I was gonna give it 26PSI for ***** on the last pass of the day but soon as power came on the shotgun went off and I didnt get very far. I threw another diff in it yesterday and shes back on the road. But something stronger is needed for spring!
The 88mm is certainly a little laggier. General driving around and on the foot brake the 76mm comes up quicker for sure. But the 88mm isnt bad at all and once it gets going comes on quick. It maybe takes a second longer on the footbrake to get 5lbs but once I adjusted for the lag at staging I could get the same 60' out of both turbos so doesnt seem too bad for the power gained up top.
Old Dec 6, 2015 | 10:20 AM
  #49
All good news. Thanks again for the review!
Old Dec 6, 2015 | 10:44 AM
  #50
Forcefed86's Avatar
What is the race weight of your chassis?
Old Dec 6, 2015 | 11:50 AM
  #51
SLOW SEDAN's Avatar
Hovers around 4000lbs. It's a Pontiac G8 with an iron 5.3L
No problem!
Old Dec 6, 2015 | 12:48 PM
  #52
turbotater1's Avatar
Comparison shot between 76 and 88:
Left 76mm, Right 88mm
88 compressor wheel
information please.which 76mm turbo are you comparing against?
Old Dec 6, 2015 | 02:37 PM
  #53
SLOW SEDAN's Avatar
Precision 7675CEA
Old Dec 8, 2015 | 03:19 PM
  #54
Precision 7675CEA
Fancy billet!
Old Dec 11, 2015 | 09:13 AM
  #55
SLOW SEDAN's Avatar
Fancy billet!
haha ya fancy wheel. That turbo is going on a manual car now.
Cant say many people would go from fancy to ebay but I had to give it a try. I'm sure a fancy wheel 88mm would be even better but for now I'm happy!
Old Dec 11, 2015 | 09:40 AM
  #56
Forcefed86's Avatar
I'm really surprised you picked up that much. The 7675CEA is a heavy hitter in the T4 world. That exh housing on the 88 sure looks big in the comparison pics above, looks larger than my 1.25 T4 S476. Do you measure back pressure?
Wonder if I'd gain anything over a "billet" T4 S476. Any side by side pics of these new 88's next to an S400 frame turbo out there?
Old Dec 11, 2015 | 11:38 AM
  #57
SLOW SEDAN's Avatar
The exhaust housing is a good bit bigger! My t4 turbo blanket doesn't even come close to covering it, but it covered the 7675 easily.
I don't currently have a way to measure back pressure.
Old Dec 11, 2015 | 11:47 AM
  #58
Forcefed86's Avatar
Yea I don’t buy into the claimed China AR housing sizes. I think they look the other turbos on ebay and copy the AR numbers without actually knowing/caring. My 1.25 housing may be a .90… not sure how we would know. I hear you can stuff clay in the hotside and get a semi accurate AR measurement. The measuring process seems pretty vague!
http://turbobygarrett.com/turbobygar...housing_sizing
Old Dec 11, 2015 | 12:49 PM
  #59
Or cut one in half and get an exact measurement.
Old Dec 11, 2015 | 05:39 PM
  #60
LT1PWRD's Avatar
How did you do at the track?
