Eboost2 issue
Old Nov 11, 2015 | 10:00 PM
BlkBird2000's Avatar
Default Eboost2 issue
Can't seem to get a reading from the controller. Car makes boost. I have the boost source for the controller hooked into my vacuum block which is plumbed in between the back of the intake and the brake booster. Is that ok? 4mm line into s larger line that goes to the vacuum block. 8 psi spring in wastegate. Over boost shutdown set at 11psi. Gate pressure at factory setting.
Old Nov 12, 2015 | 03:16 PM
old93camaro's Avatar
you sure you have the black hose going into the back of the controller?
Old Nov 12, 2015 | 03:35 PM
transam69230's Avatar
Does it read boost?
Old Nov 14, 2015 | 01:05 PM
Yes it's all hooked up correctly. Not getting a boost reading. I'm just trying to make sure that would I have it hooked up is ok?
Old Nov 15, 2015 | 01:08 PM
stevieturbo's Avatar
So if you blow into the pipe, or apply vacuum to it, you never see the reading change on the EBoost ?
Old Nov 15, 2015 | 06:48 PM
dumb question, did you setup the controller ?
Old Nov 16, 2015 | 12:48 PM
I kinked the line by accident. Reads boost but I'm not sure it's accurate. When I was wastegate only my tuner got his reading off my 2 bar map sensor and said it reads at a consistent and steady 8 psi. Now the controller is reading 13.8-14.7 with the same spring in the wastegate.
Old Nov 16, 2015 | 01:16 PM
Well there is no calibration required for the EBoost boost reading, either way it wouldnt be hard to test it with a known accurate gauge.
I'd suspect it does read correct though.
Old Nov 17, 2015 | 05:10 AM
This car trapped at 126 before the controller at a supposedly 8psi which sounds accurate. I'm going to test it with a manual boost gauge here shortly. I'll report back.
Old May 25, 2016 | 09:16 PM
Just an update.
Turns out it was messed up from the factory. They wouldn't warranty it because I bought it from someone on Amazon who turbosmart says isn't one of their dealers. So I bought a new head unit directly from turbosmart and it works as it should. The old unit was showing boost without a vacumm/boost source connected to it. Little pissed they didn't warrenty it even though it was messed up from the factory.
