I finally dyno'd the car. 862/758 spinning the tires.
#62
UNDER PRESSURE MOD
I have a 860rhwp setup that probably makes just around 800 ft/lbs of torque as well, with factory air, bigger front sway bar, stock location alternator, power steering, and factory location radiator. Oh, and full exhaust that exits at the bumper. That's a lot to ask for out of a turbo kit. I have no doubt with just a few degrees of timing, and an 11.5 afr, it would be around 900 at the wheels... not too shabby for a bolt on kit.
#63
Congrats! Those are pretty stout numbers for a real fully functional street car. Is this with a LS6, Fast or MSD intake manifold? I remember you were planning on testing out the MSD at some point.
#67
UNDER PRESSURE MOD
The tires are Toyo R888s... buuuut, they are 305/30/19s. I know, not a perfect tire, but great for doing what I love to do which is back road corner carving. It's interesting that as the tires heated up, they hooked better. How often do you see a tire spin, then hook back up. These did.
#68
