Fabrication problems. Got brakes? Nope.
Old Nov 17, 2015 | 08:32 AM
V-seriesTech's Avatar
Default Fabrication problems. Got brakes? Nope.
Well...I guess coating my WG dumps, warped them..or I don't even know what happened to be honest. We mocked up everything...test fit everything,...built jigs..... and now,..I can't even bolt on my WG tube unless I remove my master.
Yes...re fabbing is an option....unfortunately even If we redoe...I still have to figure out a way to route them. I would LIKE to change to a smaller brake master...or remote mount the reservoirs. Passenger side went on no problem, and is coated....so...I dunno.
Before
After(again....the driver side would not go on with brake master after coating)
Any of you fabricators use smaller brake masters? Or modify your setup to go remote mount? WITHOUT changing to some crazy racing pedals?
Up against a wall here.....and loosing valuable time.
Old Nov 17, 2015 | 08:38 AM
ablakez28's Avatar
Austin at STM just made aluminum reservoirs for his C5. See if he will make you a set?
Typically an EVO place but he is currently making a turbo kit for his personal car which is a c5.
http://www.streettunedmotorsports.com/contact.htm
Old Nov 17, 2015 | 08:52 AM
Well that sounds promising. Any links to his build(pics)?
Either way...I will give him a shout and see if he's interested...and what his setup looks like.
Thank you.
(still open to suggestions-thoughts).
Old Nov 17, 2015 | 09:03 AM
oscs's Avatar
Just pie cut the bend.. I could make that fit in an hour.
Old Nov 17, 2015 | 09:07 AM
ablakez28's Avatar
Thank you.
He is an excellent fabricator. I follow him on IG to keep tabs on the local EVO scene :snky: They have a shop EVO that goes 8.0 with a manual trans. WTF!
Anyhow to see pics im not sure if he is on FB(im not) but he does have an instagram. Austinatstm
Old Nov 17, 2015 | 09:11 AM
Yeah, i'd like to not have to cut up the piping.... it wasn't easy to build in the first place.
Old Nov 17, 2015 | 09:25 AM
Awesome, i'll look him up real quick. I'm Jtwells954 on IG.
Thanks for the heads up.
Old Nov 17, 2015 | 11:07 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
WTF?
The pic may make it look different, but it seems that pipe grew quite a bit towards the reservoir...
I'll ask the silly question, could you have the 2 sides mixed up, or are they not even that close in design?
Old Nov 17, 2015 | 11:21 AM
Originally Posted by Mike@Diablosport
WTF?
Sometimes I wish I was that big of a jackass lol. Although I did THINK about them being flopped....it just isn't possible. They're very different.
I am baffled as well though. Only thing I can think of is MAYBE my driverside down pipe...is sitting higher(based on these pics)...and not allowing to drop down far enough, under the reservoir? Gonna spend some more time with it tonight maybe. Honestly though the entire exhaust, which is usually super easy....fought be every inch of the way. Not sure if I can move the pipes at all but.....will try.
I do like the dudes reservoir idea though. Saw the pics,....looks nice.
Old Nov 17, 2015 | 11:30 AM
LS1Tech Sponsor
Any crazy chance the motor mounts were not fully seated/bolted in when you fabbed up the tubes?
I presume there hasn't been any heat in the exhaust since they were done...?
Old Nov 17, 2015 | 11:34 AM
Nah man that **** was solid. Zero start up attempts.
Old Nov 17, 2015 | 12:12 PM
Old Nov 17, 2015 | 03:13 PM
LS1Tech Sponsor
thats pretty trick.
Old Nov 18, 2015 | 08:03 AM
thats pretty trick.
Its a perfect appearing size. Tonight I'm gonna stay late, and see what I can or cannot get away with.
Old Nov 18, 2015 | 09:06 AM
Sleeperls's Avatar
Turn the waste gate over and drill a hole in the apron? Sucks that it moved.
Old Nov 18, 2015 | 12:03 PM
I originally ran the gate dumps directly into the tire well but it's a lot of flammage going in that area. Not the best route for me. If I ran skinnies....I could have interior pipes made and no big deal but I run 295 fronts or larger usually. No bueno for turning.
Old Nov 20, 2015 | 03:58 PM
bump for the nightly/weekend reading minds/problem solvers.
Old Nov 20, 2015 | 04:00 PM
oscs's Avatar
Just cut it up already LOL! **** would have been done days ago.
Old Nov 20, 2015 | 04:05 PM
Problem is, I don't want to have to re-engineer the side exit dumps....that wasn't cheap, or easy. By cutting it up...I loose all that time and money...plus have to have it re coated(more time lost). I would really rather not dude....as regardless of how it may look...I ain't rich or even well off lol. Besides, the car is out of my families fab shop(hour north) and in my shop now. I figure next week, I can have a friend come by(professional fabricator) and make me a reservoir. That would be the least painless....least backwards approach to what we have already done, and I don't loose my investment, so much. I am just not good enough at welding myself yet, to claim to be able to make something that holds fluid.
Old Nov 21, 2015 | 05:30 AM
97WS6SCharged's Avatar
Take it off and put a slight dent in the pipe with a hammer and a block of wood. It should still line up with everything else or at least not require much refab to make it work again.
