Treadstone TRV25-O in a Nova
This is a 3.5 inch core with 3 inch inlet and outlet. After the removal of bumper, grill, hood latch/support, I was able to put the intercooler against the core support and figure out where I was going to mount it.
The intercooler fits quite nicely in the opening for the radiator. Some choose to mount the intercooler a little lower down in order to keep the hood latch, however, this would require some major mods to the bottom of the core support which I wasn't really interested in doing and my car already has hood pins in it. After the location, both vertically and horizontally was figured out, it was time to see what was going to have to be cut from the core support in order for the couplers to be connected to the cold side. At the bottom, the vary far right (passenger) lower corner had to be removed and also a bit of the framing structure. It may be a little hard to see in the picture, but I'll try and point it out. Removing this lower corner allowed the cold side piping to be tucked under the bumper tighter and not hang way down. Also, this is possible because I have a slightly narrower radiator than some. If the radiator were stock width, the right side tank would be sitting on the part of the core support that I previously mentioned I removed.
You can see here the outline in red is what was trimmed to fit. The dotted line in yellow depicts the lower section that was cut off. You can see how this allows the cold side pipe to fit nicely up there. Some could also just put a 90 on the intercooler through the core support, but the location of my turbo wouldn't allow that to work, although I wish it would've. After temporarily mounting the intercooler, I was able to find a flat head carriage type bolt at my local big box store (Menards). This allowed me to mount the intercooler and not have the bolts interfere with the radiator tanks.
After having mounted the intercooler, it was time to see what would have to be done to the grill and filler panel. I don't have any pics of the filler panel, but for the metal support, I made a mark on it one inch wider than the intercooler and connected those two lines together with a straight line and cut out that portion. For the plastic filler, only a small section at the corner of the intercooler core had to be modified/cut out. You can't even tell it's been modified once it's all back together. Once the intercooler was in, it wouldn't let the grill sit back where it belongs. It was forward by about 1/2 inch and also the top 90 degree coupler wasn't going to fit without some trimming.
Also, the bottom of the grill had to be modified. For this I just marked the grill and cut a section out about 4 inches wide from the mark towards the center of the grill.
This allowed the bottom of the grill to be positioned correctly, well almost. Again, you'll never know it was cut once it's all back together. After trimming the grill and getting it very close, I decided to mount the left side mounting flange (driver's side) of the intercooler on the ENGINE side of the core support. Since the flanges are about 1/8-3/16 thick, this gained me the additional clearance from the grill that I needed. After that I just needed to fab up some cold side piping. I used a 4 inch holesaw to cut the openings for the upper coupler to pass through, as I'm not a fan of using a cutoff wheel and hacking a square hole for a round pipe. Here are a couple photos of the project almost completed. The grill fits around the coupler and the big radius bend fits nicely to the throttle body.
I hope this is helpful to those wanting to put an intercooler in their Nova. I'll try and update this with some pics of the filler panels and after final assembly.
by the look of that 5th pic you didn't get the 12" of snow I got yesterday. lol.
Plus, I understand the vertical flow coolers are better than horizontal flow. That being said, I was able to use a smaller cooler and leave a little more open radiator. I would assume it would take a much larger Chinese unit to equal the capabilities of the Treadstone.
IC'ers always affect air flow to the rad., so I always try and mount them lower to uncover as much of the rad. as I can, but sometimes they have to go where they can, lol
good write up, thanks
As far as effectiveness, I've noted that my buddies cars with cheap China coolers actually do a better job......but theirs are larger.
I don't have any cooling issues. But my radiator is bigger than yours. FWIW, my buddies do both have cooling issues.
Lastly, the Nova bumper covers a lot of the IC.
