please help charging issues on boosted lsx
Old Nov 22, 2015 | 06:11 PM
transam001's Avatar
Default please help charging issues on boosted lsx
i have a 02 camaro ss with a 370 ci and a s484 on it. it made 800 wheel at 16 lbs but my volts keep dropping off so i am running out of fuel. what alternator are you buys using on big hp boosed cars. i have to have a stock size because of lacation and room. thanks alot
Old Nov 22, 2015 | 06:21 PM
3 window's Avatar
How many amps is the alternator you have now? I take it you've checked the belt condition. Check grounds and do voltage drops all the way back to the battery. Bad grounds can do crazy things. Make sure there's no powder coating or anything on any brackets used for grounding. Then there might be an overdrive pulley for the alternator as well.
Old Nov 22, 2015 | 06:31 PM
transam001's Avatar
its a stock 105 amp. i have a 8 ga hotwire kit to the pumps. i have checked all grounds. i have my fans on a switch. with them on when we did a pull the volts dropped as soon as it hit boost. we did a pull with them off and the volts didnt drop till 6000. belt is tight and brand new
Old Nov 22, 2015 | 06:54 PM
3 window's Avatar
What's the normal charging voltage and what is it when it drops? Also, what pumps?
Old Nov 22, 2015 | 07:09 PM
69-chvl's Avatar
Is the volts dropping b/c it cant keep up or is the alternator cutting out and your on batt voltage? I have an issue with the alternator turning off after ~6000 rpms.
Old Nov 22, 2015 | 07:26 PM
transam001's Avatar
with my fans on it drop at about 4500 rpm ,with them off it was like 6000. volts are going to 11.6 when they drop off. were thinking that the altronator is to small and cant keep up. pumps are two 450 fed by a 8ga wire
Old Nov 22, 2015 | 07:39 PM
3 window's Avatar
The pumps are going to draw more as you up the demand. Which makes sense with what's going on. If voltage was staying up and you were losing pressure, I'd suspect a wiring issue. But that's not the case. Sounds like an alternator to me. Don't rule out a bad battery either. A bad battery can affect the charging system as well. (I'm side you knew that though). Good luck.
Old Nov 22, 2015 | 07:55 PM
transam001's Avatar
thanks for the help, i have replaced almost everything on the fuel side. regulator, in 1300 injectors all wiring , all 8 an fuel lines, fuel filters. thinking it was a fuel issue from a restriction.
Old Nov 22, 2015 | 08:06 PM
3 window's Avatar
All wiring to the relay is good as well right? A poor circuit could cause a greater draw on the system mimicking a bad alternator.
Old Nov 22, 2015 | 08:57 PM
transam001's Avatar
going to rewire that also and see if that helps.
Old Nov 22, 2015 | 10:58 PM
blackeastbeast's Avatar
I had almost the exact setup and the exact problem,after a lot of trial and error put on a 245 amp and fixed it .
Old Nov 23, 2015 | 03:02 PM
transam001's Avatar
wow a 245, i was going to get a 200
Old Nov 23, 2015 | 03:32 PM
3 window's Avatar
NO WAY you should need a 245 amp alternator. Something would be wrong. That's frickin huge!
Old Nov 23, 2015 | 04:05 PM
Yeah its overkill but I got a pretty good deal on it.
Old Nov 23, 2015 | 04:21 PM
3 window's Avatar
Well that explains it, 245 it is! Lol. I don't foresee any charging issues in your future.
Old Nov 23, 2015 | 05:25 PM
transam001's Avatar
what do you think i need 145.
Old Nov 23, 2015 | 05:36 PM
Friend of mine has a 145 truck alternator on his and it works fine.
Old Nov 23, 2015 | 05:47 PM
transam001's Avatar
ok thanks
Old Nov 23, 2015 | 06:54 PM
dw456post's Avatar
Power Bastards alternators
Old Nov 24, 2015 | 10:49 AM
stevieturbo's Avatar
For years I had no problem with my alternator, even had it repaired after a failure ( PAS leak killed it )
Next time I replaced it with a new unit mainly for convenience. This one would always stop charging about 6k.
So repaired and refitted the old again....another few years pass and again it failed. Same place repaired it locally, and all seemed well. Except now over 6k it would stop charging too.
Clearly it's something to do with the regulator/rectifier inside that it doesnt like.
I bought a 170A unit from these guys, and also had them fit a slightly larger pulley to reduce alternator speed.
https://alternatorparts.com/cs130-cs...ternators.html
Been using it last 2-3 years and it's been perfect
