Microsquirt IT RUNS THANKS FOR THE HELP
is the crank sensor wire plugged into the cam sensor plug.... it happens.
I can hook it to my car and load my tune and see if it runs if so its your harness. pm. I would like to send it out and will pay you for your time
It took me a while to get it figured out also. I was lucky that a few people on a local car forum were close to ask questions and get help from. Stick with it and you will be happy in the end.
http://www.msextra.com/downloads/
Version 340 works.
Click on the firmware 340 download link on the website listed above
Click on Agree
Select Save As and put the zipped file on your desktop
Go to your desktop and right click on the downloaded file
Select extract all
Then the Extract button
Open the extracted file folder
Disable any antivirus programs and any other running programs
During the following, do not open any other files, run any programs or click on any window
Double click on the file named 'ms2loader_win32'
A Command window will appear with directions
Follow the onscreen directions
Click on Agree
Select extract all
http://www.ebay.com/itm/RS232-DB9-Se...0AAOSwyQtVp8yS
Even fewer have serial ports though. Hence if you have a system that requires a serial port, best bet for 100% reliable comms is buy an old laptop for that purpose.
If you're lucky and do get a USB adaptor that works, dont install too much other crap that also use a lot of USB drivers that may then **** up your USB-serial adaptor
Really though, it's ridiculous any "portable" electronics these days should use a serial connection given how few laptops have that option
