can i get some help reading these plugs
Old Jun 10, 2004 | 10:12 PM
parish8's Avatar
single digit dreamer
Default can i get some help reading these plugs
these were missing above 5000rpm and have about 1500miles on them. i dont know anything about reading plugs but these dont look so good to me.
i am running leaded race fuel and the fuel is red in color, i also use the wideband regularly so i know the a/f ratio is prety close. i monitor for knock retard too and am able to avoid it. are these plugs too hot? they are tr6's. if so what plug should i change to?
Old Jun 10, 2004 | 10:36 PM
parish8's Avatar
i did a search and found this page http://www.ngksparkplugs.com/techinf...q/faqread2.asp the only pic that looks like what i have is "lead fouling" that would kind of make sence since i am running leaded fuel. anyone know if it is normal to kill a set of plugs in less than 2000miles? i would think there is still something wrong going on here since all fuel used to be leaded and they got more than 2000miles on a set.
Old Jun 10, 2004 | 10:55 PM
1dirtyZ's Avatar
if you ask me your plugs look fine except for the ornge tit, whichis like you said from the color of the gas. the thing i can't understand is the "wet" look the plug has ( i get the same on mine), could it be from oil seeping through somewhere ? or is it from the additives in gas?
Old Jun 10, 2004 | 11:11 PM
parish8's Avatar
the plugs are not wet, it is more like a shiny, clear, dry coatiing. kind of like glazed. with these plugs i prety much hit a wall at 5200rpm, change the plugs and now i rev to 6500easy. they also pulled fine at lower rpms, no missing or anything.
i dont mind changing plugs every 1000miles if i need to, it will allow me to keep an eye on things, tr6's are cheap too.
Old Jun 10, 2004 | 11:58 PM
1dirtyZ's Avatar
could it be that you are running lean somewhere in your rpm range where it causes the plug to glaze??
oh and by the way, i love your truck! i got your vids and i can't get the sound of your turbos out of my mind
Old Jun 11, 2004 | 02:43 AM
383838's Avatar
Jim, that's how a lot of leaded fuel plugs look but 1500 miles is awefully quick to kill a set. Those look like TR6's, I'd try a set of Autolite 103's instead and pull #1 and 7 after about 500 miles and compare them to the NGK's. Not sure why, but I kill NGK's quicker on leaded fuel than Autolites.
Old Jun 11, 2004 | 02:44 AM
383838's Avatar
Oh, those black specs on the plugs are not good news.
Old Jun 11, 2004 | 03:27 AM
1dirtyZ's Avatar
"those black specs on the plugs are not good news"
what are they?
Old Jun 11, 2004 | 06:35 AM
parish8's Avatar
what are they?
no kidding , fill us in. i am pushing this motor WAY harder than i should, there is bound to be some bad news. i have gone as high as 14.5psi and a 100shot and it is a mostly stock motor.
Old Jun 11, 2004 | 10:30 AM
Black Blown 02's Avatar
12 Second Truck Club
I think Black specks are either carbon or aluminum from the top of your piston, from detonaion. I know with 2-stroke bikes, if the plating is burned past the halfway point on the ground strap, the plug is too hot. From the photos, it looks like your plating is burned down about even with the ceramic.
Old Jun 11, 2004 | 10:47 AM
S_J_H's Avatar
here is a good link- Look at the glazed plugs for an explanation on what is going on. http://www.verrill.com/moto/sellingg...colorchart.htmYou need a colder plug to stop the glazing.
Old Jun 11, 2004 | 11:08 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
What a neat link Steve!!!
Jim, I have been running a set of NGK TR8's from my 746rwhp dyno pull to a week ago. I just changed over to a set of Delco plugs that Kurt reccomended, but I will probably keep a box of each on hand over the next month or so.
Old Jun 11, 2004 | 11:21 AM
parish8's Avatar
that is a sweet site
"Glazing appears as a yellowish, varnish-like color. This condition indicates that spark plug temperatures have risen suddenly during a hard, fast acceleration period. As a result, normal combustion deposits do not have an opportunity to "fluff-off" as they normally do. Instead, they melt to form a conductive coating and misfire will occur."
hmm, like when i hit the button
now is seth would just tell me about the black spots not being good news
Old Jun 11, 2004 | 11:29 AM
http://www.dfn.com/benkaren/jetfaq.html
This site is for jetting yamaha banshee's, but I think the plug reading info is kinda helpful.
Go about 3/4 down the page to the big drawing of a plug.
Old Jun 11, 2004 | 12:08 PM
LS1Tech Co-Founder
Black specks are detonation.
Old Jun 11, 2004 | 02:16 PM
383838's Avatar
John, TR8's are probably too cold for your setup.
Jim...you know I like to keep you in suspense
Old Jun 11, 2004 | 02:34 PM
LS1Tech Co-Founder
Seth, I'm not sure TR6's would be cold enough.
I am running a Delco right now.
Old Jun 11, 2004 | 02:35 PM
parish8's Avatar
Dick!
ok, i got some 103's .030?
Old Jun 11, 2004 | 02:41 PM
LS1Tech Co-Founder
Autolite 103's? What power do you think you are making?
Old Jun 11, 2004 | 02:50 PM
parish8's Avatar
i am going with the 103's because Seth said to try them, i have alot of faith in that guy, this turbo kit was his baby.
how much hp, i really have no idea but i ran over 100mph in the 1/8th. here are the numbers from smokemup.com. i used my 1/8mph because i shifted way late into 3rd and lost some mph up top. for me 2nd goes to over 100mph.
You Entered:
Vehicle Weight - 4700 (lbs)
Trap Speed - 100.45 (mph)
Drivetrain Loss - 20 (%)
Results:
Rear Wheel HP - 646.9
Crankshaft HP - 808.6
