what gears
Old Nov 30, 2015 | 07:48 AM
Seeker1056's Avatar
Default what gears
I am curious - what rear gear ratios are you turbo guys using for best spool on the street?
I have the choice of 3.08s, 3.42s, and 4.11s
I am running a 4l80e in a 3700 lb car with a 6l and soon to be finish fabricated twins
thanks
Old Nov 30, 2015 | 08:16 AM
MMorgan9812's Avatar
I run stock 3.23's at the moment but when I get my 9" going somewhere 3.40-3.50's zone
Old Dec 1, 2015 | 03:45 PM
Photochop's Avatar
What rear tire diameter? I'd opt for the 3.08 with a 26" tire, and the 3.42 with a 28"
Old Dec 1, 2015 | 03:50 PM
oscs's Avatar
@ 3700lbs im assuming Fbody so 28" would be a solid option. Id go with a 3:23 if you can. I run a 26" tire and 3:08. Twins instantly light off
Old Dec 2, 2015 | 06:54 AM
RedRocketZ28's Avatar
Between your choices, 3.42. Mine has a 3.50 gear in it. Had a 3.00 at one point and with this setup it was a dog coming out of the hole.
Old Dec 2, 2015 | 03:25 PM
RedDeadG8's Avatar
is there much of a difference between a 3:50 and a 3:70?
Old Dec 3, 2015 | 09:30 AM
93camaro_zzz's Avatar
I run 3.50, but would like to be somewhere around 3.25.
