Vacuum log
Old Dec 3, 2015 | 10:28 AM
3 window's Avatar
Default Vacuum log
Anyone ever run a log for all things requiring a vacuum signal? I was thinking of using the large connection at the back of my truck intake and go to this log.
Since it's a closed system, I was thinking I use this for the FPR, BOV, boost/vac gauge, and MAP sensor. The other question, would I need a check valve in the line to the BOV so it doesn't see boost? Any experiences would be great. Thanks in advance.
Old Dec 3, 2015 | 11:03 AM
oscs's Avatar
Works fine. I use it for everything minus MAP because it wasn't convenient. Run a big line (1/2" min) to it and you'll be fine. Also no check valve is needed.
Old Dec 3, 2015 | 11:20 AM
3 window's Avatar
Thanks. The supply line to it was planned to be 1/2". Thanks again
Old Dec 4, 2015 | 01:53 AM
Blown06's Avatar
8 Second Truck Club
I made my own out of some fuel rail stock. Works great.
Tried to find some better pics, but I don't have any. You can see it mounted on the motor plate.
Old Dec 4, 2015 | 12:45 PM
Realcanuk's Avatar
I run some hobbs switches and my BOV off one.... No issues at all.
Old Dec 4, 2015 | 08:52 PM
ScreamingL's Avatar
Changing Names
I have the fore innovations one
Old Dec 4, 2015 | 09:31 PM
3 window's Avatar
Never thought of putting the Hobbs switches in it!
