Oops
Old Dec 9, 2015 | 06:56 AM
twinturbo496's Avatar
Originally Posted by forcd ind
It shouldn't affect just one side, but what does the inlet pipe look like
Could the turbo be leaking oil-as said, wouldn't think it would be just one side
The throttle body and inlet pipe is completely dry...
I ordered 134-3609 ARP bolts & LS1 mls gaskets.
My plan at the moment is to look for an LS2 vette oil pan to replace the H3 pan I have now (the H3 pan is too low for my car). If I can find one I will pull #5 piston, if I can't find an vette pan then I will just put head gaskets and bolts in and run it again without any PCV and see what happens.
I guess I will just weld in #10 AN fittings on the valve covers and get two breathers.
Old Dec 11, 2015 | 10:02 PM
Originally Posted by gtfoxy
Can you wipe the ciylinder down a bit better? & take a pic?
Broken rings?
Old Dec 11, 2015 | 10:12 PM
SSZ's Avatar
SSZ
I was gonna guess valve seal. Did i miss something or did you check that?
Old Dec 12, 2015 | 04:31 PM
I pulled the pan and found a ¼" deep black grit in the bottom of the pan, not bearing material, more like burnt oil residue. I suppose that stuff has been sort of falling out of the engine for the last few thousand miles since it was pretty nasty inside when I bought it and I didn't really clean it up very much when I swapped the oil pan.
Since #5 did wasn't broken, I pulled #7, but really didn't find anything interesting, so I cleaned the crap out of ring lands and spring part of the oil rings since they had more of that black grit stuck in them.
Perhaps for no good reason I increased the top ring gap to .026 and the 2nd to .028 on these two cylinders and then put then back in with the same rod bearings since they looked pretty good for such high miles, but #5 upper bearing shell wasn't really 'tight' in the rod, so that may not be a great sign for this engines future...
Since it seems like everyone fails #7 or sometimes #5, I decided to leave the other pistons alone and just put it back together with new bolts, gaskets & LS6 springs.
The valve guides all "feel" pretty normal, but I am not an expert on that, so…
I got the arp bolts from a speed shop by Shreveport for about $50 less than summit with free shipping so I guess that is a good deal.
Having the engine set back a lot and having a Mohawk lift made this easier than I was expecting.
Old Dec 12, 2015 | 05:36 PM
yenkomike's Avatar
do you still have the hose from the front pass valve cover to the intake behind the throttle body. if so you are pressureizing the engine with boost and it has to go somewhere. that hose needs a check valve and your pcv can get a check valve as well so it can only suck and not blow boost itto the crankcase.
Old Dec 12, 2015 | 05:51 PM
I had the pcv valve going directly into the truck intake before, but now I am going to plug the pcv valve and just use a 1" tube to a K&N breather in each valve cover.
The port in front of the blade on the throttle body goes to the waste gates.
As an experiment, I had the 10 mm port in the right valve cover plugged instead of vented with a breather, which may have been the root cause of all of this… The engine was able to pull 5-6" of vacuum on the crankcase with the port plugged, but in hindsight, repeatedly boosting the engine and then letting off abruptly was not such a good idea and likely caused the oil to get into the chamber via both the PCV and probably past the rings…
Oh well, I suppose I needed mls gaskets anyway, and this gave me the chance to clean out the crap in the oil pan… I wonder how fast that stuff will accumulate again...
Old Dec 12, 2015 | 10:07 PM
oscs's Avatar
That's got to feel good. I was expecting a lot worse.
Old Dec 13, 2015 | 09:47 AM
Yep, unless I put it back together and it still smokes, then I am going to be pissed…
I bought an L33 a couple years ago and it came with an extra set of springs, so since I had the heads off anyway I decided to install them.
I am wondering if the GM MLS gaskets are compatible with the GM surface finish on an engine that originally had composite gaskets… I may try to sand the heads with some 600 or 800 grit.
 Michael S. Palmer
Old Dec 24, 2015 | 10:20 AM
Well… It was an oops, and entirely my fault.
EDIT: First day morning when I started the engine it still smoked… reinstalled the orifice in the turbo feed, smoked less, but still smoked… so I was not happy… I noticed that on initial start, the starter almost stopped, but didn't really think much of it at the time, I thought the battery must be low. Restarted it several times and it was fine, but the engine ran pretty poorly and missed at idle…
So day two on initial start, the starter almost stopped again… I pulled #5 plug cylinder and fuel poured out… in hindsight I am sure it was the same thing on the first day I just got lucky…
Deka 80 injectors purchased new, total run time probably less than 2 hours @ 43.5 psi.
My fault because when I initially installed them, one of them stuck open. I contacted the vendor and he said it was my fault due to contamination. (the system has a 10 micron filter plus the sock on the inlet of the 450 pump)
I even did a short video of it back then… I cycled it a few times with a 9 V battery and it started working again, so being cheap & not very smart, I decided to run it… I should have just thrown it in the trash and got a new one… FML
EDIT: I pulled all the 80# Deka injectors and installed a set of stock LS6 injectors GM#12561462 / Bosch 280 155 931. I found conflicting info about them, I assume they are 25# @ 43.5 psi… anyway, the engine runs fine with the small injectors, no smoke, started good, blah blah…
Old Dec 26, 2015 | 08:58 AM
stevieturbo's Avatar
Are they genuine Siemens injectors ? ie all part numbers etc ?
Seemingly the Chinese are faking them too ! they fake everything.
Old Dec 26, 2015 | 07:13 PM
Well, everyone says deka injectors are super reliable… but I convinced myself that the injector in #5 must be sticking… so I put in a nearly new set of stock z06 injectors, the car ran great, duty cycle was getting pretty high, but the start, idle and tip in was better than ever… I was 100% sure that the injector was the problem…. then the next morning the POS was hydraulic locked AGAIN… and again only on #5… AGAIN… 3 days in a row….I pulled the plug, liquid drained out… I couldn't believe it…
I even got a lighter and burned some liquid out of the plug to confirm it was really gasoline, not just a crack in the head or leaky head gasket…
So then it finally dawned on me that I am an idiot…
Old Dec 26, 2015 | 07:16 PM
  #32
****… really? The regulator has less than 5 hours on it with pump gas…
Old Dec 27, 2015 | 05:01 AM
  #33
Weird...
Old Dec 27, 2015 | 09:03 AM
  #34
oscs's Avatar
What regulator
Old Dec 27, 2015 | 09:05 AM
  #35
Looks like a Magnafuel
Old Dec 27, 2015 | 10:31 AM
  #36
Magnafuel 9950
I suppose the leak may have had something to do with the erratic AFR results...
Old Dec 27, 2015 | 11:00 AM
  #37
codyvette's Avatar
So now it is back with the deka injectors and a repairs/replaced regulator?
Old Dec 27, 2015 | 11:18 AM
  #38
Yes, and I guess change to 12 lb gate springs…
Old Dec 30, 2015 | 05:37 PM
  #39
New diaphragm showed up...
Installed it, set 43.5 psi, turned on the auto tune and went for an easy drive around the neighborhood...
30 minutes later: 😀... Finally.... This plug started out totally black.
Old Dec 30, 2015 | 06:15 PM
  #40
gtfoxy's Avatar
That's pretty much what happens when the stock regs puke out. Usually you notice it when your O2's get way skewed & it pops the SES.
Good catch!
