Mustang turbo setups
Old Dec 21, 2015 | 04:00 PM
Busa_rob's Avatar
Here's mine.
Btw that Griffin rad is a beast. Have one on mine.
Old Dec 21, 2015 | 04:03 PM
Busa_rob's Avatar
Attachments are being gay, here it is.
Old Dec 21, 2015 | 10:37 PM
2002camaroSS's Avatar
Originally Posted by ultraspeed
Are those the Ebay headers?
No they're built by oneguysgarage
Any closer pics of the Hotside?
Old Dec 23, 2015 | 06:48 PM
Busa_rob's Avatar
Here you go. I ended up cutting a notch in to the gram, and building a bracket to support the turbo in that notch. It's working well.
Had to notch for the oil return too.
Old Dec 26, 2015 | 10:47 AM
Thanks for the pics.
Old Dec 26, 2015 | 01:20 PM
dmracing's Avatar
Old Dec 27, 2015 | 11:31 AM
Busa_rob's Avatar
Is that the hi or mid ram? Could you post some pics from the side about fender level?? I'm going to put one on my car, courious as to how far it's gonna stick up past the hood.
Old Dec 27, 2015 | 12:16 PM
dmracing's Avatar
Hi Ram, intake off right now. This is the only other pic right now
Old Dec 27, 2015 | 01:38 PM
dmracing's Avatar
Old Dec 27, 2015 | 01:44 PM
Busa_rob's Avatar
Thanks man, that really doesn't stick up as high as I thought it would. Aje k member? How much of a cowl on the hood?
I'm doing that air to water intercooler under the plenum.
Old Dec 27, 2015 | 01:45 PM
  #32
69-chvl's Avatar
To the OP - are you looking to dump the exhaust under the hood/front of the car or run the downpipe out the back?
Old Dec 27, 2015 | 02:27 PM
  #33
mkvamso's Avatar
Heres my junk
Flipped manifolds, equal length crossover, single tial gate, turbo braced on the passenger side head.
I like the turbo facing forward, i can remove the headlight and the turbo is right there.
It does make a downpipe a bit of a challenge though.
Old Dec 27, 2015 | 03:13 PM
  #34
Thats how I was thinking of mounting mine, what turbo is that?
Old Dec 27, 2015 | 08:07 PM
  #35
mkvamso's Avatar
Precision 7675
Old Dec 27, 2015 | 09:14 PM
  #36
duke250's Avatar
Originally Posted by mkvamso
Precision 7675
What water pump is that and did you tap it for a temp sensor?
Old Dec 28, 2015 | 12:59 PM
  #37
mkvamso's Avatar
Its an fbody water pump with a different thermostat housing that comes out straight instead of at an angle
The top of the pump is tapped for the coolant temp guage in the dash.
Usually shows a few degrees warmer than the datalog/ms3 temp that usesthe factory sensor in the head.
Old Jan 9, 2016 | 12:39 PM
  #38
Thanks for all the awesome ideas.
Old Jan 9, 2016 | 12:41 PM
  #39
This is what we came up with for my car
Old Jan 9, 2016 | 12:43 PM
  #40
