Stock48 flyin low
Old Dec 15, 2015 | 09:52 PM
stock48's Avatar
9 Second Truck Club
Originally Posted by Orr89rocz
Did you try dwell adjustment?
No never messed with that part of tune.
Old Dec 15, 2015 | 11:04 PM
CameronVic's Avatar
My cam guy!
Old Dec 16, 2015 | 12:33 AM
stock48's Avatar
9 Second Truck Club
Originally Posted by Tjabo
Damn that's fast!
Questions out of left field:
1) is that sound at the end of the runs your fuel pump? If so, what kind is it?
2) is your cage legal for faster than 8.5? I'm very confused on what ETs require the "funny car" style cage...
3) What RPMs do you cruise at on the freeway with that glide, and what diameter are your tires?
Yes I have a Magnafuel 750 and it's pretty loud. It only runs when racing or comes in under boost on the street. Car street drives on a bosch 044 and it's quiet.
Cage is only good for 8.5 I was being sneaky lol Funny car cage is required for 8.49 and faster.
I can run 70~75mph at about 27~2800. 3.23 gear and 28'' tire.
Old Dec 16, 2015 | 12:39 AM
stock48's Avatar
9 Second Truck Club
Originally Posted by foxsl
Stock48, you're awesome in how you do so much with your setups result wise and then you read "stock truck intake, stock tb, stock ecu, stock coils." I like your work and the reason why I'm also sticking with similar parts
Thanks! I have a holley hp ecu on this car with firecore replacement coils.
Originally Posted by 3 window
Did you end up getting the 12 bolt in it?
Still running the 10 bolt. I paid a guy in Colorado well over a year and half ago to do the housing and get the parts and he never got it done. I will be seeing him soon...
Old Dec 16, 2015 | 01:32 AM
gnx7's Avatar
That is flyin'!
Are you running the Alper head studs or ARP? What are they torqued to?
Compstar rods?
What size/style injectors? e85?
Old Dec 16, 2015 | 01:43 AM
stock48's Avatar
9 Second Truck Club
I have the 625 studs torqued to the recommended 100 lbs, std Compstar H beam rods, E85 with 190 lb injectors.
Old Dec 16, 2015 | 08:05 AM
Tjabo's Avatar
Thanks for taking the time and being willing to answer all of the questions -- MUCH appreciated!!
Old Dec 16, 2015 | 08:32 AM
oscs's Avatar
Originally Posted by stock48
Yes before I was blowing out spark after about 23 psi. The holley HP is a great system but it does not work well with stock coils and high boost. Not sure why but I've fired up to 25 psi with .026'' + gap on my factory ecu truck with stock coils with no problem.
Why not close the gap to 18-20?
oscs's Avatar
Agreed
Old Dec 16, 2015 | 08:36 AM
asubennett's Avatar
Why close the gap if the bigger gap is firing fine now on the new coils? Wider gap = more complete burn.
Orr89rocz's Avatar
Either that and/or combined with adjust dwell. That may have helped some.
Old Dec 16, 2015 | 08:48 AM
  #32
foxsl's Avatar
Oops I meant about the 25 psi on stock ecu and truck coils
Old Dec 16, 2015 | 08:55 AM
  #33
oscs's Avatar
He was saying he had issues with it blowing out on the Holley and truck coils. I was asking why he didn't just close the gap on that setup rather than buys new coils. Just curious, not telling him what he should have done.
Old Dec 16, 2015 | 09:41 AM
  #34
stock48's Avatar
9 Second Truck Club
My point was I never had any problem firing a .025-.026" gap on 25 psi with a factory ecu and coils but my holley would lay over at .018-.020" gap with the stock coils past about 23psi. You dnt really notice it the car would just hit a wall and stop making power. The new coils are firing to 26 psi at .020" gap but think they are starting to run out of juice after that. I lost 2mph as the air got better then ran same mph after I backed boost down. That's how it was acting before. Now Im going to start playing with the dwell setting.
Old Dec 16, 2015 | 10:36 AM
  #35
oscs's Avatar
Interesting. I dropped my gap to around 19 but haven't ran it over 23lbs on these truck coils yet. Thanks for the info.
Old Dec 16, 2015 | 01:05 PM
  #36
LS1NOVA's Avatar
Job well done once again. Combo just flat works.
Old Dec 16, 2015 | 01:45 PM
  #37
3 window's Avatar
thanks! I have a holley hp ecu on this car with firecore replacement coils.
Still running the 10 bolt. I paid a guy in colorado well over a year and half ago to do the housing and get the parts and he never got it done. I will be seeing him soon...
3.08?
Old Dec 16, 2015 | 07:11 PM
  #38
stock48's Avatar
9 Second Truck Club
Thank you!
3.08?
I have 3.23 but would like to do 3.08 and a 2.10 lo gear th400 someday.
Old Dec 16, 2015 | 07:40 PM
  #39
3 window's Avatar
Thank you!
Plans for the 3.08 in the 12 bolt?
Old Dec 16, 2015 | 08:05 PM
  #40
ttls1coupe's Avatar
I have run 27lbs with no problem with my Holley HP and ls7 coils but my gap was at .18
Interesting that the truck coils wouldn't do that for you.
