Sweet Pea 1968 Chevy II Moar Door 4.8/7675/PG
#402
I’ve been trying to do research on this since I can do the same with the gold box but what is the benefit of running c02 or compressed air over just manifold pressure .... obviously manifold pressure has worked well for you
#404
#405
#412
Fuel surge tank. That way it doesn’t matter if tank pickup gets uncovered with a wheelie oe excessive G’s. Also allows me to keep the stock fuel tank.
#414
Small submersible electric fuel pump in the stock tank. I think the tank was an efi conversion tank with the pump already installed. The car had a stock tank with a sump welded in when I got it but it was leaking.
#420
