Crank Case Evacuation on Daily Driver
On my turbo LS motor, I pull fresh air from the back of the drivers side valve cover, seal the passenger valve cover up, and come out of the valley cover into the catch can. Then from the catch can it is plumbed the same as I mentioned above.
This is the best plumbing in my opinion for turbo'd V-style engines.
Now, I believe the LS6 valley cover has an effective 0.100" diameter fixed orifice. Do you worry about making more blowby gasses than can effectively pass through this orifice? I suppose the breather on the driver side cover could always assist if the crank pressure got higher than atmospheric. You ever smell crank case gasses after a WOT run?
so considering that we must have this regulation point, and that for a boosted app we also must keep boost from back feeding to the crankcase
in factory form the path of least resistance for blowby would be blown backwards out the fresh air port.. bummer because now you are consuming all the blowby your engine makes vs. clean air right when you would love clean air the most.
-also as hp increase so does this flow, and the more flow you will eventually whip up proportionately more oil with it.
so to control the situation from both ends is best, and truly manage the airflow for the new situation, sometimes better than stock.
I might start pulling from the passenger valve cover into the catch can instead, like I do on my other non LS based V-configured turbo builds. I have just been using the valley cover to keep from having to drag the fumes up through the valvetrain on the passenger head if I can avoid it. But I catch alot more on my other setups than I do on the turbo LS1...I will either switch it or add an additional line to the passenger valve cover and "Tee" it into the catch can inlet line. I like to pull from back/front corner of 1 valve cover, to opposite back/front corner of the other valve cover to try and "flush" as much of the blowby, aerated oil, fuel that has made it into the crankcase and vaporized water hanging out down there.
On my ecoboost, I collect about a GALLON of nasty fuel, water, and oil with the setup I built between every 5k mile oil change....in that order of highest to lowest concentration % of total volume captured.
I switched from the LS-6 valley source to using a valve cover due to oil pickup-after that I had trouble starting, running until it warmed up.
I blamed it on something else I did at the time, so my thinking was thrown off-I have the Holley HP running the engine, and now the engine was getting less air at idle, causing a rich cond.-I noticed the IAC was high, trying to compensate, so simply opening the throttle blade, getting the IAC to a lower #, then a throttle reset cured it-I was surprised it made that much diff
in stock form when there is no manifold vacuum accumulating fumes can and do move in both directions, and in boost obviously the only way out is back out this fresh air tube... in stock form..
