Time for an oil catch can
Old Dec 24, 2015 | 09:45 AM
forcd ind's Avatar
Default Time for an oil catch can
I noticed oil in the lines to my surge valves, and the car had been smoking some-I have a 90 deg adapter off the intake, and I use an LS 6 valley cover.
I ran a line from the valley cover to a fitting on the 90 deg adapter-right near the fitting I have fittings for the map sensor, and for the surge valves.
I guess its sucking oil into the adapter-how are you guys running catch cans
Can I come off the valley cover to a catch can, then the catch can to the intake, or should I use a valve cover instead of the valley cover
Old Dec 26, 2015 | 10:44 PM
chub406's Avatar
PM MightyMouse. Most of the members here buy his catch can. I have one. Great quality and a great guy to deal with. Lots of different options. Plus there is a diagram on the link too.
http://www.mightymousesolutions.com/#!mm-black/ca5m
Old Dec 29, 2015 | 12:17 PM
T.Fiddler's Avatar
The valley cover is not a great place to vent the engine in my experience.
I just use the stock VC vents. I am only running 8 lbs of boost though.
