LQ4 Turbo Build/Questions
-LQ4 Motor
-317 Heads with LS9 Gasket and head studs
-Z06 cam (.550 lift)
-LS7 lifters
-96mm intake and throttle body
The turbo will be a 76mm .96 A/R and I will be switching to the car to E85. Just did a little research and the car is street driven so I will be running 10 pounds of boost until I have the funds to build and convert the car to a 4L80e. I did some more research and it seems that I can run the car without an intercooler as long as I stay in the ballpark of 10 pounds like I am planning. I would like to run the downpipe directly out of the side bumper but might run it to the back through a muffler to keep the noise down...for now. Car has a 4L60e with a "stage 2" build from a local shop, a 2800 convertor, and 3.73 rear gears.
The kit will be purchased in a week or two and then I will be purchasing Siemens 80lb injectors. The car already has a Walbro 255 in tank pump. I believe that is everything, now onto the questions.
-I did some reading on the 80lb injectors and noticed they sell EV1 and EV6 injectors; what are the differences in the 2 and which ones should I purchase?
- I'm assuming I will run out of pump, but I am seeing mixed results and opinions. I would imagine the setup should put down 550 to the tires or more so which pump could I switch to if needed. I looked through a few forums on the fuel pumps and people seem to run the Walbro 450 with E85 but I am open to suggestions.
Ultimately, I am trying to get my feet wet in the turbo world and continue to build the car to go bigger and better next time around. Any and all answers/comments will be greatly appreciated.
Thank you in advance!
you have some way to go, get the car running before overwhelming yourself. can't choose a fuel pump without a power goal. the walbro you mentioned will achieve that 550 you also mentioned.
Thank you for the response!
Does anyone have experience with the Walbro 450 yet? Thank you for all the replies thus far
