Turbo Catch Can Routing Question
Thank you.
6.0 with 88/83 turbo
Stock ls1 Valley cover
2-38mm wastegates
1-50mm BOV
https://ls1tech.com/forums/generatio...ing-ok-15.html
And where is your fresh air source?
I assume I need to do this.
http://www.andersonperformance.net/p...1extfiflow.jpg
Thank you.
2-38mm wastegates
1-50mm BOV
This is worst case scenario incorrect for an FI set up. Think logically about it-when you are in boost, where can the air go? If thats a sealed can you are literally just presurizing the motor! I just bought a turbo car that had a "bad motor or turbo" for pennies on the dollar. Car smoked like a fog machine in boost. When I got it home realized he had the sealed catch can hooked up wrong (routed like yours). I added a vaccume source to the turbo and re routed the PCV. With NO other changes, I have driven the car over a month with ZERO smoke or oil leakege.
You dont need 2 catch cans, but here is an example of what I am saying.
If you dont have an intake to your turbo-you can shoehorn a barb onto your air filter- or use this in the exhaust
