4 bar GM style map senosr
Old Jan 8, 2016 | 09:30 AM
transam69230's Avatar
Default 4 bar GM style map senosr
I am running a GM 3 bar style map sensor right now with HP Tuners. I am looking to run over 30lbs this year without switching to Holley just yet (yes I know I need to switch).
Does anyone have an experience using 4bar map sensor with HP tuners?
Anyone every use one of these 4 bar GM map sensor at all, thoughts?
Old Jan 8, 2016 | 09:47 AM
93camaro_zzz's Avatar
How far you looking to push it exactly? I would be fine going all the way up to 34-35psi on a 3bar sensor.
JoeNova's Avatar
Restricted User
I'm not sure if it supports 4 bar...
Old Jan 8, 2016 | 09:54 AM
It doesn't you are correct. The sensor scaling would be off, but that could be fixed. For example 100kpa would actually be 125kpa or something along those lines.
Old Jan 9, 2016 | 08:07 AM
stevieturbo's Avatar
If you cannot re-scale for correct units, you could just use any map sensor really, do a DIY calibration so you know yourself what boost refers to what MAP sensor reading and accept the differences
It isnt a nice way to do it but as long as you know and understand what's going on it isnt a big deal. Might confuse the **** out of someone else tuning it at a later date if you didnt tell them though lol
Whilst you can peg a lower pressure sensor, I dont like doing that. I like a sensor with headroom as you can use the higher pressure values on the tables as a crude failsafe for overboost.
With a pegged sensor you cannot do that
I've only seen one seller on egay selling a 4bar GM style though, so no idea what the quality etc is like.
Other makers do sell similar though, think Bosch do a 4 bar sensor too.
