Detoxx is back & on E85
Old Jan 13, 2016 | 03:57 PM
Detoxx03's Avatar
Originally Posted by Monte4ever
I see that you have a complete 10 rib setup with the A&A bracket without one of those Flip Drive systems. Do you experience any belt slip with that setup? I'm using the same bracket but with a 8 rid and F1A. At around 5000 RPM and 13psi I get belt slip according to my logs. I end up at 8-9psi at 6500rpms. I'm currently considering using a Flip Drive system but if your 10 rib isn't slipping I may consider going that route.
By the way, bad *** car and sick HP/TQ numbers.
Tuner said there is no belt slip with this setup.
Old Jan 15, 2016 | 05:03 PM
Detoxx03's Avatar
Another point of note. The E85 tune was done at 73% with some pump gas in the tank. It will be all out and fine tuning for 85% will be done next week. Not sure what it will pick up if any but figure I'd point that out.
Old Jan 15, 2016 | 06:38 PM
FMX05's Avatar
Glad to see the car running again!
You probably won't see it pick up anything. Anything over E50 will make basically the same power unless you are throwing a **** load of timing at it.
Good luck with your physical therapy!
Old Jan 15, 2016 | 07:24 PM
02_Orange_D1SC's Avatar
formerly twolow02fransen (2014-1-2)
stock heads? or ported ?
Old Jan 15, 2016 | 10:21 PM
Detoxx03's Avatar
That's what I figured. Thanks.
Stock heads. Nothing done to them.
Old Jan 16, 2016 | 01:03 PM
Detoxx03's Avatar
Tuner has been driving my car a lot since Monday. Checking over tune, making sure there are no leaks, making sure diff and trans are fine, and other misc things. Took it to a Cars & Coffee today and all is well. He really loves the new ridetech shocks over my old pfadt units. Really smooth and not clunky. I'm really glad I went with the APR Performance carbon ZR1 spoiler too. Once I'm back in town and pick the car up it will be going to my friends shop for a full detail.
Old Jan 17, 2016 | 07:36 AM
Mekkadon's Avatar
good stuff sir. Good numbers.
Old Jan 17, 2016 | 10:39 AM
FMX05's Avatar
Our setups are very similar. I have a 408 in a C5 with an 8 rib and flip drive. Same boost and basically the same power. I'm pump/meth only. Same size pulleys, same top end. I can attest that a maxed out D1SC makes for a great street car! You have me worried about my trans and diff though. Mine only sees street driving and has a stock trans and diff.
Old Jan 17, 2016 | 05:09 PM
Detoxx03's Avatar
Thank you
What is it making on pump/meth? Nothing was wrong with my trans they just refreshed it. The diff on the other hand is a different story.
Old Jan 18, 2016 | 04:30 PM
FMX05's Avatar
Originally Posted by Detoxx03
Thank you
842whp and just over 700wtq. 20.5° timing, dual nozzle Alkycontrol setup. It has a bit more in it but I don't want to push it. My compression is about 9.5:1 so a touch lower than yours.
Old Jan 18, 2016 | 08:34 PM
Detoxx03's Avatar
Yeah that really close. I'm running 14* on pump.
Old Jan 22, 2016 | 01:04 PM
  #32
neverstop's Avatar
damn bro, that's a lot of timing for pump gas.
Old Jan 22, 2016 | 02:56 PM
  #33
stevensLS1's Avatar
Nice numbers man! Car looks amazing!! How much longer till you're back driving again?
Old Jan 22, 2016 | 04:40 PM
  #34
Detoxx03's Avatar
Thanks man. I'm gonna try and give it a test drive in a week or two to see how it feels.
Old Jan 23, 2016 | 11:11 PM
  #35
Detoxx03's Avatar
My Weld's came in yesterday. Gonna test fit them and then order tires in a few weeks.
Old Jan 25, 2016 | 05:30 AM
  #36
JRENIGAR's Avatar
Damn bro what a badass setup!!!
Old Jan 25, 2016 | 07:30 AM
  #37
RidetechJosh's Avatar
Glad to hear the shocks are doing good for you!
Old Jan 25, 2016 | 07:42 AM
  #38
oscs's Avatar
Lol no it's not
Old Jan 25, 2016 | 01:25 PM
  #39
Detoxx03's Avatar
Appreciate it man
Very nice prosit you make. Glad to do business with you.
Old Jan 27, 2016 | 04:47 PM
  #40
Appreciate it man
Same to you! If you ever have any questions, feel free to get with me!
