Detoxx is back & on E85
Old Jan 29, 2016 | 10:23 PM
  #41
Detoxx03's Avatar
Originally Posted by RidetechJosh
Same to you! If you ever have any questions, feel free to get with me!
Thanks Josh. Drove the car earlier. Absolutely love the new ridetech shocks. Huge upgrade over the pfadt's I had.
Powerband is nice. It's like a whole new car.
Old Jan 30, 2016 | 03:57 PM
  #42
neverstop's Avatar
Originally Posted by oscs
Lol no it's not
maybe he is on 93 but I'd think >20* on normal pump gas is towards the top of peak timing levels most people are running unless they're crazy low compession. I run 17 or 18* on mine with dual nozzle methanol, 9.75:1 compression and 91 pump gas
Old Jan 30, 2016 | 07:31 PM
  #43
Detoxx03's Avatar
I was running 17* on pump/meth before and 21* on race gas. Made 740 and then 780. Now have it at 14* on pump/meth and 17* on e85.
Old Feb 2, 2016 | 05:25 PM
  #44
Detoxx03's Avatar
Had the rear raised a little. That extra clearance will be handy once the Weld's and 28" M&H's go on.
Old Feb 2, 2016 | 08:53 PM
  #45
Monte4ever's Avatar
Was that straight Meth on pump gas or 50/50?
Old Feb 2, 2016 | 09:23 PM
  #46
Detoxx03's Avatar
100% is the only thing I'll use.
Old Feb 3, 2016 | 08:25 AM
  #47
conan's Avatar
LOL
Originally Posted by detoxx03
Old Feb 3, 2016 | 01:34 PM
  #48
Detoxx03's Avatar
Originally Posted by conan
LOL
A friend of mine showed me how to do that. He should have never done that
Old Feb 6, 2016 | 07:55 PM
  #49
Detoxx03's Avatar
Been driving it the last couple of days. Really feels good to be back in the saddle. I'm in love with these Ridetech shocks. I hated my old pfadt's. Powerband is nice but I need to order tires to really get a feel for all of it. Car feels a lot better in E85. Friend came over to give it s good detail.
Old Feb 10, 2016 | 08:00 PM
  #50
Detoxx03's Avatar
Switching to E85/flex fuel is one of the best mods I've ever done.
Old Feb 12, 2016 | 08:22 PM
  #51
Petraszewsky's Avatar
I'm guessing the "bypass" around the flex fuel sensor is so the massive flow of fuel isn't restricted by the 3/8" line that the sensor has? That's a neat idea and obviously it works because it doesn't sound like you're hurting for fuel even with running the E85. I'm interested because I plan on running E85 and saw that 3/8" as a restriction as well.
Old Feb 12, 2016 | 11:41 PM
  #52
Detoxx03's Avatar
You got it correct. With the ID1300s and triple pumps my duty cycle on E85 is 56% at 881rwhp. There is a guy in Arizona making over 1100whp with a YSi and the same fuel setup as me.
Old Feb 13, 2016 | 09:01 AM
  #53
I'm impressed that the ID1300s are only at 56% DC with E85 and that rwhp. I plan on using those injectors but dual Walboro 450s. I was thinking of using -8an supply and -6an return but looking closely at your pics it looks as if you're running -10an supply and -8an return. So the bypass around the flex fuel sensor is using -10an fittings? I think -8an will be enough for me even though I'm shooting for basically the exact same RWHP numbers. I will be using a Whipple 2.9 on top of a built 427 though.
Old Feb 13, 2016 | 10:09 AM
  #54
Detoxx03's Avatar
I opted for the biggest lines I could get with the Fore Innovations Fuel system since at somepoint I will build the motor and go with a F series blower. The ID's are rated at 43.5 psi so when you consider we run higher base fuel pressure they are essentially bigger than their rated.
Old Feb 13, 2016 | 10:22 AM
  #55
I appreciate the responses. Very nice build and I bet it's a blast to drive!
Old Feb 13, 2016 | 12:43 PM
  #56
Detoxx03's Avatar
Thanks man. Yeah it's been a great car over the years and now it's a brand new animal.
Old Feb 16, 2016 | 11:31 AM
  #57
94 slow's Avatar
Damn. The vette is looking good.
Is the cam in this radical? Your ci and d1 are putting down some serious numbers!
Old Feb 16, 2016 | 03:09 PM
  #58
Detoxx03's Avatar
No the cam I had in my Trans Am was bigger. 239/248 vs a 224/239 I have now.
Old Feb 16, 2016 | 07:40 PM
  #59
LilJayV10's Avatar
Awesome build. The Fore setup is bad *** for sure. We used their twin setup for E85 in a C6 at the shop. What year is your car?
Old Feb 16, 2016 | 09:10 PM
  #60
Detoxx03's Avatar
Thanks you. It's a 2008.
