Whipple build
Old May 28, 2016 | 06:16 AM
  #41
jimmyg's Avatar
This showed up yesterday. Whipple does fit under stock hood, but just touches
Old May 28, 2016 | 06:24 AM
  #42
jimmyg's Avatar
Originally Posted by montecarloss
I used all factory accessories and all factory a/c bracket and compressor from 2002 chevy truck
Ya see I used all holley mounts, crossmember, exhaust etc ...I could go your route , but I would have to notch frame. I'm hopeing the mini will fit with no notch
Old May 28, 2016 | 06:46 AM
  #43
patrick335d's Avatar
nice build,
how much higher is the 2.9 vs the stock intake?
Old May 28, 2016 | 06:50 PM
  #44
jimmyg's Avatar
Originally Posted by patrick335d
nice build,
I think it's 10.5 inches off the valley cover. It's maybe 3 in higher ? I will check it out tomorro
Old May 28, 2016 | 10:03 PM
  #45
montecarloss's Avatar
I used the brp motor mounts but I position the motor as far back( it clear the gear box(the power steering pulley), the a/c box(the ignition coils) , and I did not notch the frame( I used the muscle car oil pan) I had a 4" cowl hood and it barely clear the blower pulley. If I can help answer any questions pm me. I build the whole car by my self
Old May 28, 2016 | 10:07 PM
  #46
jimmyg's Avatar
Old May 28, 2016 | 10:12 PM
  #47
jimmyg's Avatar
This is where I'm at. I had to get a smaller belt so I cut the larger one down till it fit, clamped it together, and brought it to oreilly s and matched it up
Old May 28, 2016 | 10:14 PM
  #48
jimmyg's Avatar
Low mount Ac with a dirty dingo bracket and sd7 mini compresser
Old May 28, 2016 | 10:16 PM
  #49
jimmyg's Avatar
Also , they sent the wrong mid plate for throttlebody . So I need a smaller one or a 102 mm tb
Old May 29, 2016 | 06:26 AM
  #50
forcd ind's Avatar
Hard to tell from the pic, but I am guessing a drive by cable TB might interfere with the drive pulley?
You had to flip the drive by wire TB, or is it made with a pass side control
Looking good, keep it updated
Old May 29, 2016 | 08:16 AM
  #51
jimmyg's Avatar
According to the instructions you just flip the dbw tb. They make 3 different Venturis . I guess I just need the 90 mm Venturi
Old May 30, 2016 | 10:49 PM
  #52
jimmyg's Avatar
Old May 30, 2016 | 10:55 PM
  #53
jimmyg's Avatar
Fuel systems done. Walbro 450 -8 to -6 each side of the rails -6 to reg -6 return. I mounted the heat exchanger just need to plumb it, wire fans , etc... Pinned crank today and made my own ps lines . Definitely getting there
Old May 31, 2016 | 06:06 AM
  #54
LS1-IROC's Avatar
Cool project man! I'm thinking about trying to squeeze that same compressor in on my turbo set-up. Do you have a pic from the front, down low looking in on that area? I'm trying to figure out if my down pipe will be in the way.
Old May 31, 2016 | 07:14 PM
  #55
jimmyg's Avatar
I can get u one but not till sat
Old Jun 18, 2016 | 07:35 AM
  #56
jimmyg's Avatar
Old Jun 18, 2016 | 07:36 AM
  #57
jimmyg's Avatar
Old Jun 18, 2016 | 07:40 AM
  #58
jimmyg's Avatar
Car is basicly done. Had to swap to a 3 bar map, now I'm just waiting for mast to send me a tune. Now the intercooler fans and pump, when should they come on? Right now I have them coming on together via switch. Should the pump come on with car running? And fans on switch? Anybody know how this is set up oem?
Old Jun 19, 2016 | 10:49 AM
  #59
i would put the inter cooler pump, via a relay on you fuel pump signal.
or just run a separate switch, the fans you can put them through a temp switch, but i suppose they will be running most of the time. you would like to see as cold as possible IATs.
put a whipple, KB or maggie on my truck, is still on my wishlist.
But i got my damn radiator/ cross bracing supports above the engine, only short shy of 3"
Old Jun 19, 2016 | 12:36 PM
  #60
4K+Converter's Avatar
Nice build man! I'm thinking of doing a 4.0 whipple build in the future. I can't wait to see how your car comes out.
