How long do your plugs last?
Always run as much gap as you can afford to (without it blowing out). Larger gaps are associated with better economy and performance, as long as you get a fire started.
Your other point about AFR at idle/cruise is entirely dependent on the engine combo as the more overlap the cam has the leaner the wideband will show when the tune is in the sweet spot. Some cams will want 17:1 at idle.
As to 17:1, there may be a durability issue with long term lean idle in some applications. I do not usually shoot for such a lean ratio, although I have experimented with a great number of engines at those ratios, I tend to avoid using them for extended periods. When explaining to people new to tuning I try to emphasize the range from 14.8 to 15.2 is a safe range to idle and cruise at, a desirable number range to see consistently as you drive gently. There is not much fuel savings moving from 15:1 to 17:1 or from 14.7 to 15.2, at least not with a 1998 year of fuel injection system tech, so really the main point is just so we dont carbon everything in there up.
he said "Spraying a bit of 50/50 too, which I think I'm going to take off." So the equipment is all in place, spend $5 on some water to chase out the carbon, I am sure the chamber needs it if you've been idling at 13:1 for extended periods.
As for your 17:1 durability issue....are you familiar with the term reversion? If so, you would be aware that there are no durability issues running at 17:1 if thats what the engine wants. The wideband value is just a number on a large overlap motor at idle, it has nothing to do with what the engine wants. 14.63:1 may be fine for an engine with no overlap but will run like crap on a large overlap cam, it has nothing to do with durability.
Truck coils, stock ecu, br7ef (.022), sees 93 and c16 at the track, red gm performance wires.
It is on Holley now so I am anxious to see if i need to change coils like some have.
I run a non resistor plug still. Just use a resistor terminal on the plug wires
Seems the holley is prone to blowout issues even when everything is correct compared to the stock ECU driving the coils. It shouldn't as its a simple circuit, but it does seem to be the case
Tighter won't hurt you. I run .015 all the time now
change plugs once a year
ES is gasketed I believe, EFS is still tapered. There is a difference with the electrode though, some are regular and some are the "V" groove. I went with EFS this time around with the regular electrode. Seems the V grove makes the gap larger that what it really is.
https://www.ngk.de/uploads/tx_templa...kerbung_04.jpg
Same Holley unit from the beginning?
Perhaps yours has an issue?
Might be worth finding a shop that has an old Sun machine that will read the spark output like was done in the old days.
I have the new GM wires and BR7EFS here. Lets see how this works.
Here a pic of the current plug. Does this look real bad? Looks a little rich but I've seen alot worse. Interesting how the electrode looks pitted or fuzzy. Could the water/meth be doing that?
