Fixed all boost leaks and Bov and still bad problems!
Old Jun 13, 2004 | 08:07 PM
U-Luze's Avatar
Default Fixed all boost leaks and Bov and still bad problems!
I rerouted the boost signal to the side of the intake and now the valve closes, and the rest of the leaks are fixed. Took the car to the Pro Edelbrock event today, and the best it would do is a 8.03 at 91. But i got 7-8 lbs of boost now. Only 2 things it can be the Blower pulley is slipping on the shaft or the blower is messed up. There is no belt slip at all. I think the crank pully is pinned or keyed. So now im gonna pull the motor out tommorow and inspect it for damage, and pull the crank out of my stroker motor and have it keyed along with the crank pulley if not already done and put the stroker in. Most likely gonna upgrade to an F1R or a F2. Change all nitrile fittings out and put silicon and T-bolt clamps on it so there will be no chance of boost leakage. I talked to youngs performance and they said they can wire up the full standalone system in one day and tune. Plus its only a 4 hour drive. So thats the plans for the moment. Im ready to make it a real screamer!
Old Jun 13, 2004 | 08:20 PM
kp's Avatar
kp
Let me know if you are going to be selling the 346 incher off if its in decent shape - I'd like to upgrade the stock short block one of these days
Good luck, sounds like a fair amount of work but it should be one bad-*** car when you are done.
Old Jun 13, 2004 | 08:40 PM
U-Luze's Avatar
Yea im gonna have my buddy that worked for LPE to look at the motor and see what up. Yea ill sell it anytime when i get it running shoulnt take but a week or two.
Old Jun 13, 2004 | 08:49 PM
kp's Avatar
kp
Shoot me a PM with exactly what it is and how much you are looking to get when you are ready. As long as it doesnt have a rod hanging out the side I'm not worried about it, I'm going to go through it anyhow so I'd take it as-is if its reasonable.
Old Jun 14, 2004 | 01:26 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Justin, why not call up Kurt @ W2W, maybe you should bring it up there for a day of going over the combo. Call up Cartek or EastSide to find out if the crank is pinned.
