Whats everyone using for V bands on their hotside?
Old Feb 15, 2016 | 09:58 AM
rotary1307cc's Avatar
Originally Posted by Blown06
You are correct, the flanges with registers are a no brainer. Lapping flat flanges is a complete waist of a lot of time.
You have some awesome statements at times. Just don't fab much is my guess
Old Feb 15, 2016 | 07:58 PM
Busted67's Avatar
Interlocking works better for me, just weld them while clamped together.
Old Feb 15, 2016 | 11:16 PM
chub406's Avatar
I can understand people wanting to make sure its a true surface. Just like a blown head gasket and over heating the motor. Some people will swear you don't need to surface the head. Other people want to know they have a true surface before they put the thing together and potentially find out otherwise.
I can see how the sticking out of the flange could help seal it/hold it together.
Im not understanding why you couldn't file the mating surface on the lipped vbands? Im clearly missing something. You guys are refering the the two mating surfaces of the flanges, held together by the clamp. correct?
Old Feb 16, 2016 | 01:12 AM
Blown06's Avatar
8 Second Truck Club
I know I get "aggressive" at times. More of a way to get rid of the monotony of all talking via text. I assure you I'm harmless.
I've worked with both the flat and flanged...and to each there own really. I've never had to deal with any warping issues. So I prefer the positive register so that while I tack everything in place while it is clamped I don't have to fear any movement at the clamps.
Old Feb 16, 2016 | 10:40 PM
chub406's Avatar
Old Feb 17, 2016 | 01:29 AM
Blown06's Avatar
8 Second Truck Club
The side with the female register could be filed or "lapped".
The side with the male register probably couldn't be done in a way that would make it better.
If you're on a cold side, use the registers, file or lap the female side to make you happy, install the o-ring and you will have trouble free clamps longer than the combo will be together.
The flat v flanges work. There is a neat little trick of pushing one on a little further letting some of the pipe out. Then welding the other a little shallow to register the pipe. This is the exact same principle as a registered flange, except you don't have to measure and possibly have to sit there and hand/file fit the thing together if you didn't get it square (it was good unitl the registered flanges came about, now that process is obsolete and a waist of time).
I just like knowing 100% that I have a free flowing system that the registers provide. If the flat flanges are used and the pipes have tweaked even the slightest amount, you will not have a 100% perfect transition as some of the flange will hang over the edge of the other. It won't be much, but it will be there.
Old Feb 17, 2016 | 08:29 AM
I won't get into it I will just say you asked for one good reason..... And I provided one excellent reason.
But no that doesn't count to you
Old Feb 17, 2016 | 08:52 AM
RealQuick's Avatar
Originally Posted by LS1-IROC
I prefer the flat ones as well. I have TIG welded several sets now, and no matter what I do, they still will still warp a bit. A flat file works great at getting them true again, you can't do that with the ones that have a lip on them (unless you grind the lip off).
Have you tried clamping the mating flange on when when welding? This will prevent distortion. Its good to always have one extra Vband assembly laying around for this purpose.
Old Feb 18, 2016 | 10:54 AM
chub406's Avatar
What gage steel are you guys using for the hotside?
Old Feb 18, 2016 | 02:36 PM
RealQuick's Avatar
16ga mild steel and 16ga Stainless
Old Feb 18, 2016 | 11:32 PM
chub406's Avatar
I was reading that you cant just mig steel to stainless. That you had to get a different wire and gas. Does this sound correct? I would preferre to have them tigged. I would assume its the same principles on that though as well. Thank you for the replys.
Old Feb 19, 2016 | 01:24 AM
  #32
RonSSNova's Avatar
I got my Vbands from Columbia River.
They make the flanges in house. I watched them making them.
Mild steel. Welded with wire feed. Flat no register.
Mine did warp a smidge. I lapped with sand paper on alum plate.
Just another option
So, after the fact I didn't like the alignment so I cut some 1/2" slices of SS tubing and tacked in one side. Works great. No leaks at all.
Old Feb 20, 2016 | 05:12 AM
  #33
gols1go's Avatar
Has anyone mig welder the v bands to the stock manifolds??? If so, what type wire and gas did you use?
Old Feb 20, 2016 | 06:15 PM
  #34
RealQuick's Avatar
You can do it, but I'd preheat and u need some serious amps to penetrate.
